Updated on 2026-09-08 GMT+08:00
Overview
What Is a Record Set?
A record set translates a domain name into an IP address or other related information during DNS resolution. It defines the mapping between domain names and servers or other resources to ensure that users can find the corresponding network services when accessing domain names.
Process for Configuring a Record Set
Figure 1 shows the process for configuring a record set on the DNS console.
Figure 1 Process for configuring a record set
Related Operations
Operation
Adding Record Sets for a Public Zone
Configure record sets for public zones.
Managing Record Sets
Modify a record set, delete a record set, batch delete record sets in a single zone, and view record set details.
Managing Record Sets in Batches
Add, modify, and delete record sets in batches.
Checking a Domain Name
Check whether the record sets configured for your website or email domain have been applied. If any record sets are not applied, Huawei Cloud DNS will provide suggestions to help you address the issue.
Disabling or Enabling Record Sets
Disable or enable record sets for a domain name.
The system-generated SOA and NS record sets cannot be disabled.
Configuring a Wildcard DNS Record Set
Map all subdomains of a domain name to the same value.
Configuring an Alias Record
Associate the record set of a domain name with a Huawei Cloud resource.
  • NS and CNAME record sets cannot be associated with a cloud resource.
  • Cloud services that can be associated: Enterprise Web Portal (EWP) and Web Application Firewall (WAF)
Configuring Weighted Routing
Set weights for different record sets for load balancing, failover, and leveraging geographical location benefits.
  • You can configure weights for up to 20 record sets of the same domain name and line.
  • If the weight of a record set is set to 0, no result will be returned.
Configuring DNSSEC
Use DNSSEC to ensure the integrity and authenticity of DNS queries and responses. It helps defend your domain name against threats such as DNS spoofing and cache poisoning.
