- What's New
- Function Overview
- Getting Started
User Guide
- Public Zones
- Private Zones
- Record Sets
- PTR Records
- Intelligent Resolution
- Resolver
- Permissions Management
- Using CTS to Collect DNS Key Operations
- Access Logging
- Quota Adjustment
- Best Practices
API Reference
- Before You Start
- API Overview
- Calling APIs
- APIs
- Examples
- Appendix
- SDK Reference
DNS Overview
- Will I Be Billed for the DNS Service?
- How Many Zones, PTR Records, and Record Sets Can I Create?
- What Are Huawei Cloud DNS Servers?
- What Are Huawei Cloud Private DNS Server Addresses?
- What Are the Differences Between Public and Private Domain Names?
- Does DNS Support IPv6?
- Does DNS Support Explicit Forwarding and Implicit Forwarding?
- Does DNS Support Dynamic Domain Name Resolution?
- Does DNS Support Wildcard Entries?
- What Is TTL?
- How Many Domain Name Levels Does DNS Support?
- How Are Zones Queried to Resolve a Domain Name?
- What Are the Priorities of Resolution Lines?
- Why Was the Email Address Format Changed in the SOA Record?
- What Is CAA?
- Why Should I Set Priority For an MX Record Set?
- Can DNS Point a Domain Name to a Specific Port?
- Invalid Domain Resolution
- Website Access Failures
Public Zones
- Why Is a Message Indicating Conflict with an Existing Record Set Displayed When I Add a Record Set?
- How Do I Handle the Conflict Between CNAME and MX Record Sets?
- How Do I Add Record Sets to Subdomains?
- Which IP Address Is Returned for the Domain Name If There Are Multiple IP Addresses in a Record Set?
- Can I Modify a Zone?
- Can DNS Translate a Domain Name to IP Addresses of On-premises Servers or Third-Party Servers?
- How Can Multiple Domain Names Be Linked to the Same Website?
- Configuring Weighted Routing
- Can DNS Resolve a Domain Name that Has Not Been Licensed?
- How Do I Change the DNS Servers of a Domain Name?
- How Do I Handle Inaccurate Scheduling Caused by the CNAME Record Set Cache in the Default Lines?
Private Zones
- How Do I Change Default DNS Servers of an ECS to Huawei Cloud Private DNS Servers?
- How Can I Access an ECS Using Its Host Name?
- How Can I Map the Private IP Address of an ECS to a Domain Name?
- How Can I Use a Private Domain Name to Route Internet Traffic?
- Can I Use Private Domain Names Across Regions?
- Do I Need to Register Private Domain Names?
- Will a Deleted VPC Be Automatically Disassociated from the Private Zone?
- Are Private DNS Server Addresses the Same for All Users?
- What Are the Restrictions on Concurrent Private DNS Queries?
- Reverse Resolution
- Domain Transfer
DNS Overview
- Videos
More Documents
- Overview
- Getting Started
- Private Zone
- Record Set
- PTR Record
- Key Operations Recorded by CTS
- Quota Adjustment
- FAQs
- Change History
- API Reference (ME-Abu Dhabi Region)
User Guide (Paris Region)
- Overview
- Getting Started
- Public Zones
- Private Zones
- Record Sets
- PTR Records
- Quota Adjustment
FAQ
DNS Overview
- What Are DNS Servers?
- Does DNS Support Explicit and Implicit URLs?
- What Is TTL?
- What Is CAA?
Public Zones
- What Can I Do If There Is Message Indicating that the Public Zone Already Exists?
Private Zones
- What Are the Restrictions on Concurrent Private DNS Requests?
DNS Overview
- Change History
- API Reference (Paris Region)
- Overview
- Getting Started
- Private Zone
- Record Set
- Quota Adjustment
DNS Overview
- How Many Zones and Record Sets Can I Create?
- What Are the Private DNS Servers Provided by the DNS Service?
- Private Zones
DNS Overview
- Change History
- API Reference (Kuala Lumpur Region)
- User Guide (Ankara Region)
- API Reference (Ankara Region)
- Glossary
Adding a CAA Record Set
If you want to specify CAs authorized to issue HTTPS certificates for your domain name, add CAA record sets for the domain name.
CAA record sets are used to prevent HTTPS certificates from being incorrectly issued.
For more information about each type of record sets, see Record Set Types and Configuration Rules.
CAA record sets can be added only to public zones.
- Go to the Public Zones page.
- Locate the zone and click Manage Record Sets in the Operation column.
- Click Add Record Set.
The Add Record Set dialog box is displayed.
- Configure the parameters based on Table 1.
Table 1 Parameters for adding a CAA record set Parameter
Example Value
Type
Type of the record set
A message may be displayed, indicating that the record set you are trying to add conflicts with an existing record set of the zone.
For details, see Why Is a Message Indicating Conflict with an Existing Record Set Displayed When I Add a Record Set?
CAA – Grant certificate issuing permissions to CAs
Name
Prefix of the domain name to be resolved.
For example, if the domain name is example.com, the prefix can be as follows:
- www: The domain name is www.example.com, which is usually used for a website.
- Left blank: The domain name is example.com.
To use an at sign (@) as the domain name prefix, just leave this parameter blank.
- abc: The domain name is abc.example.com, a subdomain of example.com.
- mail: The domain name is mail.example.com, which is usually used for email servers.
- *: The domain name is *.example.com, which is a wildcard domain name, indicating all subdomains of example.com.
Left blank
Line
Resolution line. The DNS server uses information about end users' carrier networks or geographical locations to determine the most appropriate server IP address to return.
The default value is Default.
This parameter is only configurable for public zone record sets.
- Default: returns the default resolution result when no resolution line is set based on end users' carrier networks or geographical locations.
- ISP: returns the resolution result based on end users' carrier networks. For details, see Configuring ISP Lines.
- Region: returns the resolution result based on end users' geographical locations. For details, see Configuring Region Lines.
Default
TTL (s)
Cache duration of the record set on a local DNS server, in seconds.
The value ranges from 1 to 2147483647, and the default value is 300.
If your service address changes frequently, set TTL to a smaller value.
Learn more about TTL.
300
Value
CA to be authorized to issue certificates for a domain name or its subdomains
You can enter up to 50 different IP addresses, each on a separate line.
The format is [flag] [tag] [value].
Configuration rules:
- flag: CA identifier, an unsigned character ranging from 0 to 255. Usually, the value is set to 0.
- tag: You can enter 1 to 15 characters. Only letters and digits from 0 to 9 are allowed. The tag can be one of the following:
- issue: authorizes a CA to issue all types of certificates.
- issuewild: authorizes a CA to issue wildcard certificates.
- iodef: requests notifications once a CA receives invalid certificate requests.
- value: authorized CA or email address/URL required for notification once the CA receives invalid certificate requests. The value depends on the value of tag and must be enclosed in quotation marks (""). The value can contain no more than 255 characters. Only letters, digits, spaces, and special characters -#*?&_~=:;.@+^/!% are allowed.
0 issue "ca.abc.com"
0 issuewild "ca.def.com"
0 iodef "mailto:admin@domain.com"
0 iodef "http:// domain.com/log/"
Weight
(Optional) Weight for the record set. The value ranges from 0 to 1000, and the default value is 1.
If a resolution line in a zone contains multiple record sets of the same type, you can set different weights to each record set. For details, see Configuring Weighted Routing.
Tag
(Optional) Identifier of the record set. Each tag contains a key and a value. You can add up to 20 tags to a record set.
For details about tag key and value requirements, see Table 2.
If your organization has configured tag policies for the DNS service, you need to add tags to your record sets based on the tag policies. If you add a tag that does not comply with the tag policies, record sets may fail to be created. Contact the administrator to learn more about tag policies.
example_key1
example_value1
(Optional) Supplementary information about the record set.
The description can contain no more than 255 characters.
Table 2 Tag key and value requirements Parameter
Requirements
Example Value
Key
- Cannot be left blank.
- Must be unique for each resource.
- Can contain no more than 36 characters.
- Cannot start or end with a space nor contain special characters =*<>\,|/
example_key1
Value
- Can contain no more than 43 characters.
example_value1
- Switch back to the Record Sets tab.
The added record set is in the Normal state.
Related Operations
For more information about CAA record sets, see Setting CAA Record Sets to Prevent Unauthorized HTTPS Certificate Issuing.
