On this page
Adding an SRV Record Set
To tag a server to show what services it provides, you can add SRV record sets for a domain name.
For more information about each type of record sets, see Record Set Types and Configuration Rules.
  1. Go to the DNS console.
  2. In the navigation pane on the left, choose Public Zones or Private Zones.
    The zone list is displayed.
  3. (Optional) If you have selected Private Zones, click on the upper left corner to select the region and project.
  4. Locate the zone and click Manage Record Sets in the Operation column.
  5. Click Add Record Set.
    The Add Record Set dialog box is displayed.
  6. Configure the parameters based on Table 1.
    Table 1 Parameters for adding an SRV record set
    Example Value
    Type
    Type of the record set
    A message may be displayed, indicating that the record set you are trying to add conflicts with an existing record set of the zone.
    For details, see Why Is a Message Indicating Conflict with an Existing Record Set Displayed When I Add a Record Set?
    SRV – Record servers providing specific services
    Name
    Service (for example, FTP, SSH, or SIP) provided over the specified protocol (for example, TCP or UDP) on a host
    The format is _Service name._Protocol.
    _ftp._tcp
    _ftp._tcp indicates that the host provides the FTP service over TCP.
    Line
    Resolution line. The DNS server uses information about end users' carrier networks or geographical locations to determine the most appropriate server IP address to return.
    The default value is Default.
    This parameter is only configurable for public zone record sets.
    • Default: returns the default resolution result when no resolution line is set based on end users' carrier networks or geographical locations.
    • ISP: returns the resolution result based on end users' carrier networks. For details, see Configuring ISP Lines.
    • Region: returns the resolution result based on end users' geographical locations. For details, see Configuring Region Lines.
    Default
    TTL (s)
    Cache duration of the record set on a local DNS server, in seconds.
    The value ranges from 1 to 2147483647, and the default value is 300.
    If your service address changes frequently, set TTL to a smaller value.
    Learn more about TTL.
    300
    Value
    Server address
    You can enter up to 50 different IP addresses, each on a separate line.
    The value format is [priority] [weight] [port number] [server address].
    Configuration rules:
    • The priority, weight, and port number range from 0 to 65535.
    • A smaller value indicates a higher priority.
    • A larger value indicates a larger weight.
    • The server address is the domain name of the target server.
      Ensure that the domain name can be resolved.
    If the record set values have the same priority, requests to the domain name will be routed based on weights.
    2 1 2355 example_server.test.com
    Weight
    (Optional) Weight for the record set. The value ranges from 0 to 1000, and the default value is 1.
    If a resolution line in a zone contains multiple record sets of the same type, you can set different weights to each record set. For details, see Configuring Weighted Routing.
    Tag
    (Optional) Identifier of the record set. Each tag contains a key and a value. You can add up to 20 tags to a record set.
    For details about tag key and value requirements, see Table 2.
    If your organization has configured tag policies for the DNS service, you need to add tags to your record sets based on the tag policies. If you add a tag that does not comply with the tag policies, record sets may fail to be created. Contact the administrator to learn more about tag policies.
    example_key1
    example_value1
    (Optional) Supplementary information about the record set.
    The description can contain no more than 255 characters.
    Table 2 Tag key and value requirements
    Requirements
    Example Value
    Key
    • Cannot be left blank.
    • Must be unique for each resource.
    • Can contain no more than 36 characters.
    • Cannot start or end with a space nor contain special characters =*<>\,|/
    example_key1
    Value
    • Can contain no more than 43 characters.
    example_value1
  7. Click OK.
  8. Switch back to the Record Sets tab.
    The added record set is in the Normal state.
