Searching for Record Sets
The DNS service allows you to centrally manage record sets in both public and private zones.
You can quickly search for record sets by its status, type, name, value, tag, or ID.
In the following operations, record sets of a private zone are used as an example.
- Go to the DNS console.
- On the Dashboard page, click Record Sets.
The record set list is displayed.
- Click Private Zone Record Sets.
- Set search criteria to search for record sets.
The following search criteria are available:
- Domain Name: Search for record sets by domain name.
- Value: Search for record sets using their values.
- ID: Search for record sets based on their IDs.
- Status: Search for record sets in a specified state.
- Type: Search for record sets of a specified type.
- Tag: Search for record sets using predefined tags.
- Click Modify or Delete to perform desired record set operations.
