Obtaining Temporary Credentials from a Flink Job's Agency for Accessing Other Cloud Services
Function
DLI provides a common interface to obtain temporary credentials from Flink job's agencies set by users during job launch. The interface encapsulates temporary credentials obtained from the job agency in the com.huaweicloud.sdk.core.auth.BasicCredentials class.
- Encapsulate temporary credentials obtained from the agency in the return value of getCredentials() of the com.huaweicloud.sdk.core.auth.ICredentialProvider interface.
- The return type is com.huaweicloud.sdk.core.auth.BasicCredentials.
- Only AKs, SKs, and security tokens can be obtained.
- After obtaining the AK, SK, and security token, query temporary credentials by referring to Using CSMS to Change Hard-coded Database Account Passwords.
Notes and Constraints
- Agency authorization for accessing temporary credentials is only supported in Flink 1.15.
- When creating a Flink job, select version 1.15.
- The information of the agency that allows DLI to access DEW has been configured for the job. flink.dli.job.agency.name indicates the custom agency name.
For details about how to create a custom agency, see Customizing DLI Agency Permissions.
Note that double quotes ("") or single quotes ('') are not required when configuring parameters.
- The Flink 1.15 base image has built-in huaweicloud-sdk-core 3.1.62.
Preparing the Environment
Development tools such as IntelliJ IDEA and other development tools, JDK, and Maven have been installed and configured.
Dependency package in POM file configurations
<dependency>
<groupId>com.huaweicloud.sdk</groupId>
<artifactId>huaweicloud-sdk-core</artifactId>
<version>3.1.62</version>
<scope>provided</scope>
</dependency>
Sample Code
This section's Java sample code demonstrates how to obtain BasicCredentials and retrieve a temporary agency's AK, SK, and security token.
- Obtaining job agency credentials using Flink UDFs
package com.huawei.dli.demo; import static com.huawei.dli.demo.utils.DLIJobAgencyCredentialUtils.getICredentialProvider; import com.huaweicloud.sdk.core.auth.BasicCredentials; import com.huaweicloud.sdk.core.auth.ICredentialProvider; import org.apache.flink.table.functions.FunctionContext; import org.apache.flink.table.functions.ScalarFunction; import org.slf4j.Logger; import org.slf4j.LoggerFactory; public class GetUserAgencyCredentialUDF extends ScalarFunction { private static final Logger LOG = LoggerFactory.getLogger(GetUserAgencyCredentialUDF.class); ICredentialProvider credentialProvider; @Override public void open(FunctionContext context) throws Exception { credentialProvider = getICredentialProvider(); } public String eval(String value) { BasicCredentials basicCredentials = (BasicCredentials) credentialProvider.getCredentials(); String ak = basicCredentials.getAk(); String sk = basicCredentials.getSk(); String securityToken = basicCredentials.getSecurityToken(); LOG.info(">>> ak " + ak + " sk " + sk.length() + " token " + securityToken.length()); return value + "_demo"; } }
- Obtaining job agency credentials for Flink Jar jobs
package com.huawei.dli.demo; import static com.huawei.dli.demo.utils.DLIJobAgencyCredentialUtils.getICredentialProvider; import com.huaweicloud.sdk.core.auth.BasicCredentials; import com.huaweicloud.sdk.core.auth.ICredentialProvider; import org.apache.flink.streaming.api.datastream.DataStream; import org.apache.flink.streaming.api.environment.StreamExecutionEnvironment; import org.slf4j.Logger; import org.slf4j.LoggerFactory; import org.apache.flink.streaming.api.functions.source.ParallelSourceFunction; public class GetUserCredentialsFlinkStream { private static final Logger LOG = LoggerFactory.getLogger(GetUserCredentialsFlinkStream.class); public static void main(String[] args) throws Exception { StreamExecutionEnvironment streamEnv = StreamExecutionEnvironment.getExecutionEnvironment(); DataStream<String> stream = streamEnv.addSource(new DataGen()).disableChaining(); ICredentialProvider credentialProvider = getICredentialProvider(); BasicCredentials basicCredentials = (BasicCredentials) credentialProvider.getCredentials(); String ak = basicCredentials.getAk(); String sk = basicCredentials.getSk(); String securityToken = basicCredentials.getSecurityToken(); LOG.info(">>" + " ak " + ak + " sk " + sk.length() + " token " + securityToken.length()); stream.print(); streamEnv.execute("GetUserCredentialsFlinkStream"); } private static class DataGen implements ParallelSourceFunction<String> { private boolean isRunning = true; private int count = 0; public void run(SourceContext<String> ctx) throws Exception { while (isRunning) { for (long i = 0; i < 10; i++) { ctx.collect("data-" + count); count++; } Thread.sleep(1000); } } public void cancel() { isRunning = false; } } }
- Tool class for obtaining job agencies
package com.huawei.dli.demo.utils; import com.huaweicloud.sdk.core.auth.ICredentialProvider; import org.apache.flink.streaming.api.environment.StreamExecutionEnvironment; import java.util.ArrayList; import java.util.List; import java.util.ServiceLoader; public class DLIJobAgencyCredentialUtils { public static ICredentialProvider getICredentialProvider() { List<ICredentialProvider> credentialProviders = new ArrayList<>(); ServiceLoader.load(ICredentialProvider.class, StreamExecutionEnvironment.class.getClassLoader()) .iterator() .forEachRemaining(credentialProviders::add); if (credentialProviders.size() != 1) { throw new RuntimeException("Failed to obtain temporary user credential"); } return credentialProviders.get(0); } }
