Using CTS to Audit DLI
With CTS, you can log operations related to DLI, making it easier to search, audit, and trace in the future.
| Operation | Resource Type | Trace Name |
| Creating a database | database | createDatabase |
| Deleting a database | database | deleteDatabase |
| Changing the database owner | database | alterDatabaseOwner |
| Creating a table | table | createTable |
| Dropping a table | table | deleteTable |
| Exporting table data | table | exportData |
| Importing table data | table | importData |
| Changing the owner of a table | table | alterTableOwner |
| Creating a queue | queue | createQueue |
| Deleting a queue | queue | deleteQueue |
| Granting permissions to a queue | queue | queueAuthorize |
| Modifying the CIDR block of a queue | queue | replaceQueue |
| Restarting a queue | queue | queueActions |
| Scaling out/in a queue | queue | queueActions |
| Submitting a job (SQL) | queue | submitJob |
| Canceling a job (SQL) | jobs | cancelJob |
| Granting DLI the permission to access OBS buckets | obs | authorizeObsBucketsForStream |
| Checking SQL syntax | jobs | checkSQL |
| Deleting a job | jobs | deleteStreamJob |
| Creating a Flink OpenSource SQL job | jobs | createStreamSqlJob |
| Updating a Flink OpenSource SQL job | jobs | updateStreamSqlJob |
| Deleting Flink jobs in batches | jobs | deleteStreamJobs |
| Stopping a Flink job | jobs | stopStreamJobs |
| Submitting a Flink job | jobs | submitStreamJobs |
| Creating a Flink Jar job | jobs | createStreamJarJob |
| Updating a Flink Jar job | jobs | updateStreamJarJob |
| Viewing Flink jobs | jobs | checkStreamJob |
| Importing a savepoint | jobs | dealSavepoint |
| Purchasing CUH packages | order | orderPackage |
| Granting data permissions | authorization | dataAuthorize |
| Granting permissions on other projects | authorization | projectDataAuthorize |
| Exporting query results | jobs | storeJobResult |
| Saving a SQL template | template | createTemplate |
| Updating a SQL template | template | updateTemplate |
| Deleting a SQL template | template | deleteTemplates |
| Creating a Flink template | template | createStreamTemplate |
| Updating a Flink template | template | updateStreamTemplate |
| Viewing Flink templates | template | checkStreamTemplate |
| Deleting a Flink template | template | deleteStreamTemplate |
| Creating a datasource authentication and uploading a certificate | datasourceauth | uploadAuthInfo |
| Updating datasource authentication information | datasourceauth | updateAuthInfo |
| Deleting datasource authentication information | datasourceauth | deleteAuthInfo |
| Uploading a resource package | resource | uploadResources |
| Deleting a resource package | resource | deleteResource |
| Creating an enhanced datasource connection | edsconnection | createConnection |
| Deleting an enhanced datasource connection | edsconnection | deleteConnection |
| Creating a basic datasource connection | edsconnection | createConnection |
| Deleting a basic datasource connection | edsconnection | deleteConnection |
| Binding a queue | edsconnection | associateQueueToConnection |
| Unbinding a queue | edsconnection | disassociateQueueToConnection |
| Modifying host information | edsconnection | updateHostInfo |
| Adding a route | edsconnection | addRoute |
| Deleting a route | edsconnection | deleteRoute |
| Creating a batch processing job | jobs | createBatch |
| Canceling a batch processing job | jobs | cancelBatch |
| Creating a global variable | variable | createGlobalVariable |
| Deleting a global variable | variable | deleteGlobalVariable |
| Modifying a global variable | variable | updateGlobalVariable |
| Querying resources by enterprise project | tms | tmsQueryResources |
| Creating an elastic resource pool | elasticresourcepool | createElasticResourcePool |
| Deleting an elastic resource pool | elasticresourcepool | deleteElasticResourcePool |
| Updating an elastic resource pool | elasticresourcepool | updateElasticResourcePool |
| Binding a queue to an elastic resource pool | elasticresourcepool | associateQueueToElasticResourcePool |
| Updating the queue properties of an elastic resource pool | elasticresourcepool | updateElasticResourcePoolQueuePriority |
For how to enable CTS and view trace details, see Cloud Trace Service Overview.
For details about key fields in the CTS trace structure, see Trace Structure and Example Traces.
