- What's New
User Guide
- Preparations
- IAM Permissions Management
- Data Management
- Data Integration
- Data Development
- Solution
- O&M and Scheduling
- Configuration and Management
- Specifications
- Usage Tutorials
References
Nodes
- Node Overview
- CDM Job
- DIS Stream
- DIS Dump
- DIS Client
- Rest Client
- Import GES
- MRS Kafka
- Kafka Client
- CS Job
- DLI SQL
- DLI Spark
- DWS SQL
- MRS SparkSQL
- MRS Hive SQL
- MRS Presto SQL
- MRS Spark
- MRS Spark Python
- MRS Flink Job
- MRS MapReduce
- CSS
- Shell
- RDS SQL
- ETL Job
- OCR
- Create OBS
- Delete OBS
- OBS Manager
- Open/Close Resource
- Data Quality Monitor
- Subjob
- SMN
- Dummy
- For Each
- EL
Nodes
- Change History
- API Reference
- What Is DLF?
- What Is DLF Used For?
- What Is a Job?
- How Many Jobs Can Be Created in DLF?
- Can I Adjust the Job Quota in DLF?
- Does DLF Provide Job Templates?
- What Is a Node?
- Is There a Limit on the Number of Nodes Contained in a DLF Job?
- How Can I Quickly Rectify a Deleted CDM Cluster Associated with a Job?
- What Causes a Large Difference Between the Plan Time and Start Time of a Job?
- How Do I Change the Message Language?
- What Can I Do When a Job Fails?
- Glossary
Developing a Spark Job
This section introduces how to develop a Spark job on Data Development.
Scenario Description
In most cases, SQL is used to analyze and process data when using Data Lake Insight (DLI). However, SQL is usually unable to deal with complex processing logic. In this case, Spark jobs can help. This section uses an example to demonstrate how to submit a Spark job on Data Development.
The general submission procedure is as follows:
- Create a DLI cluster and run a Spark job using physical resources of the DLI cluster.
- Obtain a demo JAR package of the Spark job and associate with the JAR package on Data Development.
- Create a Data Development job and submit it using the DLI Spark node.
Preparations
Obtaining Spark Job Codes
The Spark job code used in this example comes from the maven repository (download address: Spark job code). Download spark-examples_2.10-1.1.1.jar. The Spark job is used to calculate the approximate value of π.
- After obtaining the JAR package of the Spark job codes, upload it to the OBS bucket. The save path is s3a://dlfexample/spark-examples_2.10-1.1.1.jar.
- In the navigation tree of the console, choose Configuration > Manage Resource. Create resource spark-example on Data Development and associate it with the JAR package obtained in 1.
Figure 1 Creating a resource
Submitting a Spark Job
You need to create a job on Data Development and submit the Spark job using the DLI Spark node of the job.
- Create an empty DLF job named job_spark.
Figure 2 Creating a job
- Go to the job development page, drag the DLI Spark node to the canvas, and click the node to configure node properties.
Figure 3 Configuring node properties
Description of key properties:
- DLI Cluster Name: Name of the Spark cluster created in Preparations.
- Job Running Resource: Maximum CPU and memory resources that can be used when a DLI Spark node is running.
- Major Job Class: Main class of a DLI Spark node. In this example, the main class is org.apache.spark.examples.SparkPi.
- JAR Package: Resource created in 2.
- After the job orchestration is complete, click
to test the job.
Figure 4 Job logs (for reference only) - If no problems are recorded in logs, click
to save the job.
