CS Job
Functions
The CS Job node is used to execute a predefined Cloud Stream Service (CS) job for real-time analysis of streaming data.
Context
This node enables you to start a CS job or query whether a CS job is running. If you do not select an existing real-time job, DLF creates and starts the job based on the job status configured on the node. You can customize jobs and use DLF job parameters.
Parameters
Table 1 and Table 2 describe the parameters of the CS Job node.
| Parameter | Mandatory | Description |
| Job Type | Yes | Select a job type for CS.
| Existing CS job | ||
| Streaming Job Name | Yes | Name of the CS job to be executed. To create a CS job, you can use either of the following methods:
| Node Name | Yes | Name of the node. Must consist of 1 to 128 characters and contain only letters, digits, underscores (_), hyphens (-), slashes (/), less-than signs (<), and greater-than signs (>). |
| Flink SQL job | ||
| SQL Script | Yes | Path to a script to be executed. If the script is not created, create and develop the script by referring to Creating a Script and Developing an SQL Script. |
| Script Parameter | Yes | If the associated SQL script uses a parameter, the parameter name is displayed. Set the parameter value in the text box next to the parameter name. The parameter value can be a built-in function and EL expression. For details about built-in functions and EL expressions, see Expression Overview. |
| CloudStream Cluster | Yes | Name of the CS cluster. To create a CS cluster, go to the CS console. |
| SPUs | Yes | 1 SPU = 1 core and 4 GB memory |
| Parallelism | Yes | Number of tasks that run CS jobs at the same time. You are advised to set this parameter to 1 or 2 times of the SPU. |
| UDF JAR | No | After the JAR package is imported, you can use SQL statements to call the custom functions in the package. You need to upload the JAR package to the OBS bucket. |
| Auto Restart upon Exception | No | If you enable this function, the system automatically restarts and restores abnormal CS jobs upon job exceptions. |
| Streaming Job Name | Yes | Name of the Flink SQL job. The name is 1 to 57 characters long and consists only of letters, digits, hyphens (-), and underlines (_). |
| User-defined Flink job | ||
| JAR Package Path | Yes | The JAR package path can be selected only after you have uploaded the custom JAR package to the OBS bucket. |
| Main Class | No | Name of the main class in the JAR file to be uploaded, for example, KafkaMessageStreaming. If this parameter is not specified, the main class name is determined based on the Manifest file in the JAR file. |
| Main Class Parameter | No | List of parameters for the main class. Parameters are separated by spaces, for example, test tmp/result.txt. |
| Driver SPU | Yes | Number of SPUs used for each driver node. |
| Streaming Job Name | Yes | Name of the user-defined Flink job. The name is 1 to 57 characters long and consists only of letters, digits, hyphens (-), and underlines (_). |
| User-defined Spark job | ||
| Executors | Yes | Number of the executor nodes. |
| Executor SPUs | Yes | Number of SPUs used for each executor node. |
| Streaming Job Name | Yes | Name of the user-defined Spark job. The name is 1 to 57 characters long and consists only of letters, digits, hyphens (-), and underlines (_). |
| Node Status Polling Interval (s) | Yes | Specifies how often the system check completeness of the node task. The value ranges from 1 to 60 seconds. |
| Max. Node Execution Duration | Yes | Execution timeout interval for the node. If retry is configured and the execution is not complete within the timeout interval, the node will not be retried and is set to the failed state. |
| Retry upon Failure | Yes | Indicates whether to re-execute a node task if its execution fails. Possible values:
NOTE: If Timeout Interval is configured for the node, the node will not be executed again after the execution times out. Instead, the node is set to the failure state. |
| Failure Policy | Yes | Operation that will be performed if the node task fails to be executed. Possible values:
