Shell
Functions
The Shell node is used to execute a shell script.
With EL expression #{Job.getNodeOutput()}, you can obtain the desired content (4000 characters at most and counted backwards) in the output of the shell script run by the Shell node.
Example:
To obtain <name>jack<name1> from a shell script (script name: shell_job1) output, enter the following EL expression:
#{StringUtil.substringBetween(Job.getNodeOutput("shell_job1"),"<name>","<name1>")} Parameters
Table 1 and Table 2 describe the parameters of the Shell node.
| Parameter | Mandatory | Description |
| SQL Statement or Script | Yes | You can select SQL statement or SQL script.
| Host Connection | Yes | Selects the host where a shell script is to be executed. |
| Script Parameter | No | Parameter transferred to the script when the shell script is executed. Parameters are separated by spaces. For example: a b c. The parameter must be referenced by the shell script. Otherwise, the parameter is invalid. |
| Interactive Input | No | Interactive information (passwords for example) provided during shell script execution. Interactive parameters are separated by carriage return characters. The shell script reads parameter values in sequence according to the interaction situation. |
| Node Name | Yes | Name of the node. Must consist of 1 to 128 characters and contain only letters, digits, underscores (_), hyphens (-), slashes (/), less-than signs (<), and greater-than signs (>). |
| Node Status Polling Interval (s) | Yes | Specifies how often the system check completeness of the node task. The value ranges from 1 to 60 seconds. |
| Max. Node Execution Duration | Yes | Execution timeout interval for the node. If retry is configured and the execution is not complete within the timeout interval, the node will not be retried and is set to the failed state. |
| Retry upon Failure | Yes | Indicates whether to re-execute a node task if its execution fails. Possible values:
NOTE: If Timeout Interval is configured for the node, the node will not be executed again after the execution times out. Instead, the node is set to the failure state. |
| Failure Policy | Yes | Operation that will be performed if the node task fails to be executed. Possible values:
