RDS SQL
Functions
The RDS SQL node is used to transfer SQL statements to RDS.
Parameters
Table 1 and Table 2 describe the parameters of the RDS SQL node.
Parameter |
Mandatory |
Description |
Node Name |
Yes |
Name of the node. Must consist of 1 to 128 characters and contain only letters, digits, underscores (_), hyphens (-), slashes (/), less-than signs (<), and greater-than signs (>). |
Data Connection |
Yes |
Name of the data connection. |
Database |
Yes |
Name of the database. The database has been created. You are advised not to use the default database. |
SQL or Script |
Yes |
You can select SQL statement or SQL script.
Parameter |
Mandatory |
Description |
Node Status Polling Interval (s) |
Yes |
Specifies how often the system check completeness of the node task. The value ranges from 1 to 60 seconds. |
Max. Node Execution Duration |
Yes |
Execution timeout interval for the node. If retry is configured and the execution is not complete within the timeout interval, the node will not be retried and is set to the failed state. |
Retry upon Failure |
Yes |
Indicates whether to re-execute a node task if its execution fails. Possible values:
If Timeout Interval is configured for the node, the node will not be executed again after the execution times out. Instead, the node is set to the failure state. |
Failure Policy |
Yes |
Operation that will be performed if the node task fails to be executed. Possible values:
