On this page
DWS SQL
Functions
The DWS SQL node is used to transfer an SQL statement to DWS.
Context
This node enables you to execute DWS statements during batch or real-time job processing. You can use parameter variables to perform incremental import and process partitions for your data warehouses.
Parameters
Table 1, Table 2, and Table 3 describe the parameters of the DWS SQL node.
Table 1 Parameters of DWS SQL nodes
Mandatory
SQL Statement or Script
Yes
You can select SQL statement or SQL script.
  • SQL Statement
    In the SQL statement text box, enter the SQL statement to be executed.
  • SQL Script
    Select a script to be executed. If the script is not created, create and develop the script by referring to Creating a Script and Developing an SQL Script.
    If you select the SQL statement mode, the DLF cannot parse the parameters contained in the SQL statement.
Data Connection
Yes
Data connection that is configured in the SQL script. The value can be changed.
Database
Yes
Database that is configured in the SQL script. The value can be changed.
Script Parameter
No
If the associated SQL script uses a parameter, the parameter name is displayed. Set the parameter value in the text box next to the parameter name. The parameter value can be a built-in function and EL expression. For details about built-in functions and EL expressions, see Expression Overview.
If the parameters of the associated SQL script are changed, click to refresh the parameters.
Dirty Data Table
No
Enter the name of the dirty data table defined in the SQL script.
Node Name
Yes
Name of the SQL script. The value can be changed. The rules are as follows:
Name of the node. Must consist of 1 to 128 characters and contain only letters, digits, underscores (_), hyphens (-), slashes (/), less-than signs (<), and greater-than signs (>).
Table 2 Advanced parameters
Mandatory
Node Status Polling Interval (s)
Yes
Specifies how often the system check completeness of the node task. The value ranges from 1 to 60 seconds.
Max. Node Execution Duration
Yes
Execution timeout interval for the node. If retry is configured and the execution is not complete within the timeout interval, the node will not be retried and is set to the failed state.
Retry upon Failure
Yes
Indicates whether to re-execute a node task if its execution fails. Possible values:
  • Yes: The node task will be re-executed, and the following parameters must be configured:
    • Maximum Retries
    • Retry Interval (seconds)
  • No: The node task will not be re-executed. This is the default setting.
If Timeout Interval is configured for the node, the node will not be executed again after the execution times out. Instead, the node is set to the failure state.
Failure Policy
Yes
Operation that will be performed if the node task fails to be executed. Possible values:
  • End the current job execution plan
  • Go to the next job
  • Suspend the current job execution plan
  • Suspend execution plans of the current and subsequent nodes
Table 3 Lineage
Input
Add
Click Add. In the Type drop-down list, select the type to be created. The value can be DLI, DWS, OBS, or CSS.
  • DWS
    • Connection Name: Click . In the displayed dialog box, select a DWS data connection.
    • Database: Click . In the displayed dialog box, select a DWS database.
    • Schema: Click . In the displayed dialog box, select a DWS schema.
    • Table Name: Click . In the displayed dialog box, select a DWS table.
  • OBS
    • Path: Click . In the displayed dialog box, select an OBS path.
  • CSS
    • Cluster Name: Click . In the displayed dialog box, select a CSS cluster.
    • Index: name of the CSS index.
  • DLI
    • Connection Name: Click . In the displayed dialog box, select a DLI data connection.
    • Database: Click . In the displayed dialog box, select a DLI database.
    • Table Name: Click . In the displayed dialog box, select a DLI table.
OK
Click OK to save the parameter settings.
Cancel
Click Cancel to cancel the parameter settings.
Edit
Click to modify the parameter settings. After the modification, save the settings.
Delete
Click to delete the parameter settings.
View Details
Click to view details about the table created based on the input lineage.
Output
Add
  • DWS
  • OBS
  • CSS
    • Index: Enter a CSS index name.
  • DLI
OK
Cancel
Edit
Delete
Table Details
Click to view details about the table created based on the output lineage.
