- What's New
User Guide
- Preparations
- IAM Permissions Management
- Data Management
- Data Integration
- Data Development
- Solution
- O&M and Scheduling
- Configuration and Management
- Specifications
- Usage Tutorials
References
Nodes
- Node Overview
- CDM Job
- DIS Stream
- DIS Dump
- DIS Client
- Rest Client
- Import GES
- MRS Kafka
- Kafka Client
- CS Job
- DLI SQL
- DLI Spark
- DWS SQL
- MRS SparkSQL
- MRS Hive SQL
- MRS Presto SQL
- MRS Spark
- MRS Spark Python
- MRS Flink Job
- MRS MapReduce
- CSS
- Shell
- RDS SQL
- ETL Job
- OCR
- Create OBS
- Delete OBS
- OBS Manager
- Open/Close Resource
- Data Quality Monitor
- Subjob
- SMN
- Dummy
- For Each
- EL
Nodes
- Change History
- API Reference
- What Is DLF?
- What Is DLF Used For?
- What Is a Job?
- How Many Jobs Can Be Created in DLF?
- Can I Adjust the Job Quota in DLF?
- Does DLF Provide Job Templates?
- What Is a Node?
- Is There a Limit on the Number of Nodes Contained in a DLF Job?
- How Can I Quickly Rectify a Deleted CDM Cluster Associated with a Job?
- What Causes a Large Difference Between the Plan Time and Start Time of a Job?
- How Do I Change the Message Language?
- What Can I Do When a Job Fails?
- Glossary
Show all
Instance Monitoring
In the navigation tree of the Data Development console, choose Monitoring. On the Monitor Instance page, you can view the job instance information and perform more operations on instances and nodes as required. For details, see Batch Processing: Viewing All Instances.
If the job instance is in the Failed state, you can mouse over the question mark and view the pop-up message to understand the failure cause, as shown in Figure 1.
Rerunning Job Instances
You can rerun a job instance that is successfully executed or fails to be executed by setting its rerun position.
- Log in to the DLF console.
- In the navigation tree of the DLF console, choose Monitoring > Monitor Instance.
- In the Operation column of a job, click Rerun to rerun the job instance. Alternatively, click the check box on the left of a job, and then click the Rerun button to rerun the job.
Figure 2 Setting the rerunning position
Table 1 Parameter description Parameter
Rerun From
Select the start position from which the job instance reruns.
- Error node: When a job instance fails to be run, it reruns since the error node of the job instance.
- The first node: When a job instance fails to be run, it reruns since the first node of the job instance.
- Specified node: When a job instance fails to be run, it reruns since the node specified in the job instance.
A job instance reruns from its first node if either of the following cases occurs:
- The quantity or name of a node in the job changes.
- The job instance has been successfully run.
