- What's New
User Guide
- Preparations
- IAM Permissions Management
- Data Management
- Data Integration
- Data Development
- Solution
- O&M and Scheduling
- Configuration and Management
- Specifications
- Usage Tutorials
References
Nodes
- Node Overview
- CDM Job
- DIS Stream
- DIS Dump
- DIS Client
- Rest Client
- Import GES
- MRS Kafka
- Kafka Client
- CS Job
- DLI SQL
- DLI Spark
- DWS SQL
- MRS SparkSQL
- MRS Hive SQL
- MRS Presto SQL
- MRS Spark
- MRS Spark Python
- MRS Flink Job
- MRS MapReduce
- CSS
- Shell
- RDS SQL
- ETL Job
- OCR
- Create OBS
- Delete OBS
- OBS Manager
- Open/Close Resource
- Data Quality Monitor
- Subjob
- SMN
- Dummy
- For Each
- EL
Nodes
- Change History
- API Reference
- What Is DLF?
- What Is DLF Used For?
- What Is a Job?
- How Many Jobs Can Be Created in DLF?
- Can I Adjust the Job Quota in DLF?
- Does DLF Provide Job Templates?
- What Is a Node?
- Is There a Limit on the Number of Nodes Contained in a DLF Job?
- How Can I Quickly Rectify a Deleted CDM Cluster Associated with a Job?
- What Causes a Large Difference Between the Plan Time and Start Time of a Job?
- How Do I Change the Message Language?
- What Can I Do When a Job Fails?
- Glossary
Show all
Creating a Database
After creating a data connection, you can manage the databases under the data connection in the area on the right.
The following types of databases can be created:
- DLI
- DWS
- MRS Hive
A data connection has been created. For details, see Creating a Data Connection.
- Log in to the DLF console.
- In the navigation tree of the Data Development console, choose Data Development > Develop Script/Data Development > Develop Job.
- In the menu on the left, click
, right-click the data connection for which you want to create a database, and choose Create Database from the shortcut menu. Set database parameters. Table 1 describes the database parameters.
You can create a maximum of 10 databases for a DLI data connection. No quantity limit is set on other types of data connections.
Table 1 Creating a database Parameter
Mandatory
Database Name
Yes
Name of the database. The naming rules are as follows:
- DLI: The value must consist of 1 to 128 characters and contain only letters, digits, and underscores (_). It must start with a digit or letter and cannot contain only digits.
- DWS: The value must consist of 1 to 63 characters and contain only letters, digits, underscores (_), and dollar signs ($). It must start with a letter or underscore and cannot contain only digits.
- MRS Hive: The value must consist of 1 to 128 characters and contain only letters, digits, and underscores (_). It must start with a digit or letter and cannot contain only digits.
No
Descriptive information about the database. The requirements are as follows:
- DLI: The value contains a maximum of 256 characters.
- DWS: The value contains a maximum of 1024 characters.
- MRS Hive: The value contains a maximum of 1024 characters.
- Click OK.
