MRS Presto SQL
Functions
The MRS Presto SQL node is used to execute a predefined Presto SQL script on Data Development.
Parameters
Table 1 and Table 2 describe the parameters of the MRS Presto SQL node.
Parameter |
Mandatory |
Description |
SQL Script |
Yes |
Path to a script to be executed. If the script is not created, create and develop the script by referring to Creating a Script and Developing an SQL Script. |
Data Connection |
Yes |
Data connection that is configured in the SQL script. The value can be changed. |
Schema |
Yes |
Database that is configured in the SQL script. The value can be changed. |
Script Parameter |
No |
If the associated SQL script uses a parameter, the parameter name is displayed. Set the parameter value in the text box next to the parameter name. The parameter value can be a built-in function and EL expression. For details about built-in functions and EL expressions, see Expression Overview. If the parameters of the associated SQL script are changed, click |
Node Name |
Yes |
Name of the SQL script. The value can be changed. The rules are as follows: Name of the node. Must consist of 1 to 128 characters and contain only letters, digits, underscores (_), hyphens (-), slashes (/), less-than signs (<), and greater-than signs (>). |
Parameter |
Mandatory |
Description |
Node Status Polling Interval (s) |
Yes |
Specifies how often the system check completeness of the node task. The value ranges from 1 to 60 seconds. |
Max. Node Execution Duration |
Yes |
Execution timeout interval for the node. If retry is configured and the execution is not complete within the timeout interval, the node will not be retried and is set to the failed state. |
Retry upon Failure |
Yes |
Indicates whether to re-execute a node task if its execution fails. Possible values:
If Timeout Interval is configured for the node, the node will not be executed again after the execution times out. Instead, the node is set to the failure state. |
Failure Policy |
Yes |
Operation that will be performed if the node task fails to be executed. Possible values:
