Data Quality Monitor
Functions
The Data Quality Monitor node is used to monitor the quality of running data.
Parameters
Table 1 and Table 2 describe the parameters of the Data Quality Monitor node.
| Parameter | Mandatory | Description |
| Node Name | Yes | Name of the node. Must consist of 1 to 128 characters and contain only letters, digits, underscores (_), hyphens (-), slashes (/), less-than signs (<), and greater-than signs (>). |
| Quality Rule Name | Yes | Name of the rule for monitoring the running data. For details about how to create a rule, see the DAYU User Guide. |
| Max. Node Execution Duration | Yes | Execution timeout interval for the node. If retry is configured and the execution is not complete within the timeout interval, the node will not be retried and is set to the failed state. |
| Retry upon Failure | Yes | Indicates whether to re-execute a node task if its execution fails. Possible values:
NOTE: If Timeout Interval is configured for the node, the node will not be executed again after the execution times out. Instead, the node is set to the failure state. |
| Failure Policy | Yes | Operation that will be performed if the node task fails to be executed. Possible values:
