Updated on 2025-06-26 GMT+08:00
Dumping Data to OBS
Dumping the JSON, BLOB, and CSV Data to the Text Data
Table 1 Parameters for configuring a Text dump file
Value
Task Name
Name of the dump task. The names of dump tasks created for the same stream must be unique. A dump task name is 1 to 64 characters long. Only letters, digits, hyphens (-), and underscores (_) are allowed.
Dump Bucket
Name of the OBS bucket used to store data from the DIS stream. The bucket name is created when you create a bucket in OBS.
File Directory
Directory created in OBS to store files from the DIS stream.
This directory name is 0 to 50 characters long.
By default, this parameter is left unspecified.
Time Directory Format
Data will be saved according to the time format in the file directory of the OBS bucket.
For example, if the time directory is accurate to day, the save path will be in the format of bucket name/file directory/year/month/day.
Possible values are as follows:
  • N/A: If this field is left unspecified, the time directory format will not be used.
  • yyyy: year.
  • yyyy/MM: year and month.
  • yyyy/MM/dd: year, month, and day.
  • yyyy/MM/dd/HH: year, month, day, and hour.
  • yyyy/MM/dd/HH/mm: year, month, day, hour, and minute.
You can only select but not enter a value in this field.
Record Delimiter
Delimiter used to separate different dump records.
  • Comma (,)
  • Semicolon (;)
  • Vertical bar (|)
  • Newline (\n)
  • NULL
Offset
  • Latest: Maximum offset, indicating that the latest data will be read.
  • Earliest: Minimum offset, indicating that the earliest data will be read.
Latest
Dump Interval (s)
Interval at which data from the DIS stream will be imported into dump destination, such as OBS. If no data was pushed to the DIS stream during the time specified here, the dump file will not be generated.
Value range: 30s to 900s
Unit: second
Default value: 300s
Dumping the JSON Data to the CSV Data
Table 2 Parameters for configuring a CSV dump file
Value
Task Name
Dump Bucket
File Directory
  • yyyy: year.
Offset
Latest
Dump Interval (s)
User-defined interval at which data is imported from the current DIS stream into the target place. If no data is pushed to the DIS stream during the current interval, no dump file package will be generated.
Unit: second
Default value: 300s
Dumping the JSON and CSV Data to the Parquet Data
Table 3 lists the differentiated parameters that need to be set when the source data type is JSON or CSV, the dump destination is OBS, and the dump file format is Parquet. For details about how to configure other common parameters, see Table 1.
Table 3 Parameters for configuring a Parquet dump file
Value
Source Data Schema
JSON or CSV data example, used to describe the JSON or CSV data format. DIS can generate an Avro schema based on the JSON or CSV data sample and convert the uploaded JSON or CSV data to the Parquet format.
File Directory
This directory name is 0 to 100 characters long.
When the source data type is JSON, EL and built-in functions are supported.
  • EL example
Source data:
{"name":"Andy","city":"","time":1556323141582}
The dump file directory is configured as follows:
dis/basePath/app_key_p=${name}
The final directory structure is as follows:
{$Bucket name}/dis/basePath/app_key_p=Andy
  • Example of built-in functions
Source data:
dis/basePath/date_p=toDate(${time}, "yyMMdd")
{$Bucket name}/dis-basePath/date_p=20190427
Supported built-in functions
toDate(timestamp, format): Convert the time stamp to a specified time format. For example: toDate (1556323141582, 'yymmdd')
Custom Time Directory
You can click or to disable or enable the custom time directory.
  • If the custom timestamp is disabled, the directory where the object file written to OBS resides is named after the creation time of the dump file.
    For example, if a dump file was created on October 16, 2018 and the time directory format is accurate to day, the file will be saved in OBS bucket name/dump file directory/2018/10/16.
  • If the custom timestamp is disabled, the directory where the object file written to OBS resides is named in the time format specified in the source data.
    For example, if a dump file was created on October 16, 2018, the time directory format is accurate to day, and the time format specified in the data source is 2017/09/08 11:01:01, the file will be saved in OBS bucket name/dump file directory/2017/09/08. The storage directory is defined based on the time format defined in the source data instead of the time when the dump file is created.
  • Example 1: Dump simple JSON data.
Source data:
{ "id":"1", "date":"2018/10/16 11:00:05"}
The configuration is as follows:
Set the timestamp attribute name to date, data type to String, and timestamp format to yyyy/MM/dd HH:mm:ss based on the source data type of the data to be dumped.
After the data is dumped successfully, the storage directory structure depends on the source data timestamp and the time directory format. In this example, the time directory format is accurate to day. Therefore, the final data storage directory is OBS bucket name/dump file directory/2018/10/16.
  • Example 2: Dump multiply layers of nested JSON data.
    Source data:
    { "id":"1", "detail":{ "detID":"05790110000000000103#567fd3cb13a4493eaa43076953253eed", "endTime":"2018/10/07 13:26:35" }}
Set the timestamp attribute name to detail.endTime, data type to String, and timestamp format to yyyy/MM/dd HH:mm:ss based on the source data type of the data to be dumped.
After the data is dumped successfully, the storage directory structure depends on the source data timestamp and the time directory format. In this example, the time directory format is accurate to day. Therefore, the final data storage directory is OBS bucket name/dump file directory/2018/10/07.
  • Example 3: Dump CSV data.
Source data:
a,2010-10-12 11:00:00,b,2011-10-12 11:00:10
Select timestamp 2010-10-12 11:00:00 based on the source data to be dumped. After data is converted to the Parquet format, the corresponding attribute field name is field_1. When creating a dump task, set the timestamp attribute to field_1, data type to String, and timestamp format to yyyy/MM/dd HH:mm:ss.
After the data is dumped successfully, the storage directory structure depends on the source data timestamp and the time directory format. In this example, the time directory format is accurate to day. Therefore, the final data storage directory is OBS bucket name/dump file directory/2010/10/12.
Source Data Timestamp
  • Attribute name of the timestamp.
    Enter the field name corresponding to the timestamp defined in the source data to be uploaded.
  • Timestamp format. Possible values can be:
    yyyy/MM/dd HH:mm:ss
    MM/dd/yyyy HH:mm:ss
    dd/MM/yyyy HH:mm:ss
    yyyy-MM-dd HH:mm:ss
    MM-dd-yyyy HH:mm:ss
    dd-MM-yyyy HH:mm:ss
  • Data type. Possible values can be:
    • String
    • Timestamp
      If the type of the source data to be uploaded is Timestamp, the value must be accurate to milliseconds.
