- What's New
- Getting Started
User Guide
- IAM Permissions Management
- Getting Started
- Managing DIS Streams
Using DIS
- Checking and Configuring DNS Information
- Uploading Data by Using Agent
- Using DIS Flume Plugin to Upload and Download Data
- Using a DIS Logstash Plugin to Upload and Download Data
- Using Kafka Adapter to Upload and Download Data
- Using SparkStreaming SDK to Download Data
- Using a DIS Flink Connector to Upload and Download Data
- Managing a Dump Task
- Managing Enterprise Projects
- Notifying Events
- Monitoring
- Best Practices
SDK Reference
- Overview
- Related Resources
- Enabling DIS
- Creating a DIS Stream
- Obtaining Authentication Information
Getting Started with SDK
Using the Java SDK
- Preparing the Environment
- Configuring a Sample Project
- Initializing a DIS SDK Client Instance
- Creating a Stream
- Creating a Dump Task
- Updating a Dump Task
- Deleting a Dump Task
- Querying a Dump Task List
- Querying Dump Details
- Deleting a Stream
- Querying a Stream List
- Querying Stream Details
- Downloading Streaming Data
- Uploading Streaming Data
- Obtaining the Data Cursor
- Creating an Application
- Deleting an Application
- Adding a Checkpoint
- Querying a Checkpoint
- Changing Partition Quantity
Using the Python SDK
- Preparing the Installation Environment
- Creating a Stream
- Deleting a Stream
- Uploading Streaming Data in JSON Format
- Uploading Streaming Data in Protobuf Format
- Viewing Application Details
- Querying an Application List
- Obtaining a Data Cursor
Using the Java SDK
- Error Codes
- Change History
- API Reference
General Questions
- What Is DIS?
- What Is a Partition?
- What Can I Do with DIS?
- What Advantages Does DIS Have?
- Which Modules Do DIS Have?
- How Do I Create a DIS Stream?
- What Is the Difference Between Storing Data into DIS and Dumping Data Elsewhere?
- How Do I Check Software Package Integrity?
- How Do I Send and Retrieve Data Using DIS?
- What Is Data Control?
- Dump Questions
- DIS Agent Questions
General Questions
On this page
Show all
Help Center/
Data Ingestion Service/
User Guide/
Using DIS/
Using DIS Flume Plugin to Upload and Download Data/
Installing a DIS Flume Plugin
PuTTY has been installed.
- Log in to the remote Flume server using PuTTY or another remote login tool.
- Run the following command to navigate to the Flume installation directory:
cd ${FLUME_HOME}
- Upload the dis-flume-plugin-X.X.X.zip installation package to this directory.
- Run the following command to decompress the installation package:
unzip dis-flume-plugin-X.X.X.zip
- Run the following command to navigate to the directory where the package is decompressed:
cd dis-flume-plugin
- Run the following command to execute the installation program:
bash install.sh
If the following information is displayed, the DIS Flume Plugin has been successfully installed in the ${FLUME_HOME}/plugin.d/dis-flume-plugin directory:
Install dis-flume-plugin successfully.
Parent topic: Using DIS Flume Plugin to Upload and Download Data
