- What's New
- Function Overview
- Billing
- Getting Started
User Guide
- Key Management Service
- Cloud Secret Management Service
- Key Pair Service
- Dedicated HSM
- Tag Management
- Auditing Logs
- Sharing
- Permission Control
Best Practices
- General
API Reference
- Before You Start
- Calling APIs
- API Overview
APIs
Key Management APIs
- Key Lifecycle Management
- DEK Management
- Small-Size Data Encryption and Decryption
- Signature and Verification
- Key Tag Management
- Key API Version Query
- Querying Key API Versions
- Key Import Management
- Querying Keys
- Key Grant Management
- Key Rotation Management
- Dedicated Keystore Management
- Signature Verification
- Key Pair Management APIs
- Secret Management APIs
Key Management APIs
- Historical APIs
- Application Examples
- Appendix
- SDK Reference
KMS Related
- What Is Key Management Service?
- What Is a Customer Master Key?
- What Is a Default Key?
- What Are the Differences Between a Custom Key and a Default Key?
- What Is a Data Encryption Key?
- Why Cannot I Delete a CMK Immediately?
- Which Cloud Services Can Use KMS for Encryption?
- How Do Huawei Cloud Services Use KMS to Encrypt Data?
- What Are the Benefits of Envelope Encryption?
- Is There a Limit on the Number of Custom Keys That I Can Create on KMS?
- Can I Export a CMK from KMS?
- Can I Decrypt My Data if I Permanently Delete My Custom Key?
- How Do I Use the Online Tool to Encrypt or Decrypt Small Volumes of Data?
- Can I Update CMKs Created by KMS-Generated Key Materials?
- When Should I Use a CMK Created with Imported Key Materials?
- What Should I Do When I Accidentally Delete Key Materials?
- How Are Default Keys Generated?
- What Should I Do If I Do Not Have the Permissions to Perform Operations on KMS?
- Why Can't I Wrap Asymmetric Keys by Using -id-aes256-wrap-pad in OpenSSL?
- Key Algorithms Supported by KMS
- What Should I Do If KMS Failed to Be Requested and Error Code 401 Is Displayed?
- What Is the Relationship Between the Ciphertext and Plaintext Returned by the encrypt-data API?
- How Does KMS Protect My Keys?
- How Do I Use an Asymmetric Key to Verify the Signature Result of a Public Key Pair?
- Does an Imported Key Support Rotation?
- Does KMS Support Offline Data Encryption and Decryption?
- How Do I Convert an Original EC Private Key into a Private Key in PKCS8 Format?
- CSMS Related
KPS Related
- How Do I Create a Key Pair?
- What Are a Private Key Pair and an Account Key Pair?
- How Do I Handle an Import Failure of a Key Pair Created Using PuTTYgen?
- What Should I Do When I Fail to Import a Key Pair Using Internet Explorer 9?
- How Do I Log In to a Linux ECS with a Private Key?
- How Do I Use a Private Key to Obtain the Password to Log In to a Windows ECS?
- How Do I Handle the Failure in Binding a Key Pair?
- How Do I Handle the Failure in Replacing a Key Pair?
- How Do I Handle the Failure in Resetting a Key Pair?
- How Do I Handle the Failure in Unbinding a Key Pair?
- Do I Need to Restart Servers After Replacing Its Key Pair?
- How Do I Enable the Password Login Mode for an ECS?
- How Do I Handle the Failure in Logging In to ECS After Unbinding the Key Pair?
- What Should I Do If My Private Key Is Lost?
- How Do I Convert the Format of a Private Key File?
- Can I Change the Key Pair of a Server?
- Can a Key Pair Be Shared by Multiple Users?
- How Do I Obtain the Public or Private Key File of a Key Pair?
- What Can I Do If an Error Is Reported When an Account Key Is Created or Upgraded for the First Time?
- Will the Account Key Pair Quota Be Occupied After a Private Key Pair Is Upgraded to an Account Key Pair?
- Why Is the Private Key Pair Invisible After It Is Upgraded to an Account Key Pair When Logging in as a Federated User?
Dedicated HSM Related
- What Is Dedicated HSM?
- How Does Dedicated HSM Ensure the Security for Key Generation?
- Do Equipment Room Personnel Has the Super Administrator Role to Steal Information by Using a Privileged UKey?
- What HSMs Are Used for Dedicated HSM?
- What APIs Does Dedicated HSM Support?
- How Do I Enable Public Access to a Dedicated HSM Instance?
- Pricing
General
- What Functions Does DEW Provide?
- What Cryptography Algorithms Does DEW Use?
- In Which Regions Are DEW Services Available?
- What Is a Quota?
- What Is the Resource Allocation Mechanism of DEW?
- What Are Regions and AZs?
- Can DEW Be Shared Across Accounts?
- How Do I Access the Functions of DEW?
- Why Do DEW Pemissions Fail to Take Effect Immediately?
KMS Related
- Videos
More Documents
- User Guide (ME-Abu Dhabi Region)
- User Guide (Paris and Amsterdam Regions)
User Guide
- Auditing Logs
KMS Related
- How Do Cloud Services Use KMS to Encrypt Data?
- What Types of Keys Can I Import?
- Credential Related
KMS Related
- Change History
- Before You Start
- Calling APIs
- API Overview
APIs
- Creating a CMK
- Enabling a CMK
- Disabling a CMK
- Scheduling the Deletion of a CMK
- Canceling the Scheduled Deletion of a CMK
- Querying the List of CMKs
- Querying the Information About a CMK
- Creating a Random Number
- Creating a DEK
- Creating a Plaintext-Free DEK
- Encrypting a DEK
- Decrypting a DEK
- Querying the Number of Instances
- Querying the Quota of a User
- Changing the Alias of a CMK
- Changing the Description of a CMK
- Encrypting Data
- Decrypting Data
- Obtaining CMK Import Parameters
- Importing CMK Material
- Deleting CMK Material
- Querying CMK Instances
- Querying CMK Tags
- Querying Project Tags
- Adding or Deleting CMK Tags in Batches
- Adding a CMK Tag
- Deleting a CMK Tag
- Appendix
- Change History
API Reference (Paris and Amsterdam Regions)
- Before You Start
- Calling APIs
- API Overview
APIs
- Creating a CMK
- Enabling a CMK
- Disabling a CMK
- Creating a DEK
- Encrypting a DEK
- Decrypting a DEK
- Creating a Grant
- Revoking a Grant
- Retiring a Grant
- Querying Grants on a CMK
- Querying Grants That Can Be Retired
- Encrypting Data
- Decrypting Data
- Enabling Rotation for a CMK
- Changing the Rotation Interval for a CMK
- Disabling Rotation for a CMK
- Querying the Rotation Status of a CMK
- Appendix
- Change History
- Before You Start
- Calling APIs
- API Overview
APIs
- Creating a CMK
- Enabling a CMK
- Disabling a CMK
- Creating a DEK
- Encrypting a DEK
- Decrypting a DEK
- Creating a Grant
- Revoking a Grant
- Retiring a Grant
- Encrypting Data
- Decrypting Data
- Appendix
- Change History
Critical Operation Protection
Operation protection is supported in secret management. If you want to perform critical operations on the console, an identify verification method is required. Enable this function for your account security. It will take effect for both the account and users under the account.
Only operations that are performed on the console are protected by this function.
Enabling operation protection
- On the console, locate the user name in the upper right corner, and select Security Settings from the drop-down list.
Figure 1 Security settings
- Go to the security settings page and click Critical Operations. Locate Operation Protection and click Enable.
- On the Operation Protection page, choose Enable, and click OK to enable operation protection.
In this case, if you or the IAM users under your account perform critical operations such as viewing secret value or deleting a key, you are required to enter a verification code, avoiding risks and loss for your service.
- When performing a critical operation, you will be asked to choose a verification method from email, SMS, and virtual MFA device.
- If you only bind a phone number, only SMS verification is available for verification.
- If you only bind an email address, only email is available for verification.
- If you have not bound any method, bind one to perform critical operations.
- To modify the verification phone number, email address, or the virtual MFA device, see Basic Information.
Verifying the Operation Protection
If you have enabled operation protection, there will be a verification when you perform critical operations such as viewing the secret value. Select a verification mode based on your bound information, as shown in Figure 2.
- If you have bound an email address, enter the email verification code.
- If you have bound a mobile number, enter the SMS verification code.
- If you have bound a virtual MFA device, enter the 6-digit dynamic verification code on the MFA device.
Disabling Operation Protection
Figure 3 Security settings
- Go to the security settings page and click Critical Operations. Locate Operation Protection and click Modify.
- On the Operation Protection page, choose Disable, click OK, and pass the verification.
