Updated on 2026-09-11 GMT+08:00
Viewing Metric and Event Monitoring Data
You can view DEW metrics on Cloud Eye to learn about the DEW protection status in a timely manner and set protection policies based on the metrics.
DEW has been interconnected with Cloud Eye, that is, alarm rules have been set on Cloud Eye. For details about how to set alarm monitoring rules, see Setting Alarm Rules.
Viewing Metric Monitoring Data
  1. Log in to the Cloud Eye console.
  2. Click in the upper left corner and select a region or project.
  3. In the navigation pane on the left, choose Cloud Service Monitoring.
  4. Search for KMS or CSMS, click the dashboard name to view the service monitoring details.
  5. Locate the target key or secret instance and click View Metric in the Operation column.
Viewing Event Monitoring Data
  3. In the navigation pane on the left, choose Event Monitoring.
  4. On the displayed page, view all system events and custom events over the last 24 hours.
    You can view events in the last 1 hour, last 3 hours, last 12 hours, last 1 day, last 7 days, or last 30 days. Alternatively, you can set a custom time range to view events triggered within that period.
    Table 1 Event monitoring list
    Event Type
    Event type, which can be either system event or custom event.
    Event Name
    User operation that triggered an event, such as login and logout.
    For details about the system events supported by DEW, see Events Supported by DEW.
    Event Source
    Service the event is generated for.
    Quantity
    Number of times that the event is reported in the selected period.
    Last Occurred At
    Time when the event last occurred.
    Operation
    You can view the monitoring graph and create alarm rules.
  5. Locate the event type to be viewed and click View Graph in the Operation column.
  6. Locate a specific event and click View Event in the Operation column.
