Updated on 2025-07-30 GMT+08:00
Viewing Dedicated HSM Instances
This section describes how to view the Dedicated HSM instance information, including the name/ID, status, service version, device vendor, device model, IP address, and creation time.
  1. Log in to the DEW console.
  2. Click in the upper left corner and select a region or project.
  3. In the navigation pane on the left, choose Dedicated HSM.
  4. Check the Dedicated HSM instance information in the list. The following table describes the parameters.
    Table 1 Dedicated HSM instance parameters
    Name/ID
    Name and ID of a Dedicated HSM instance
    Status
    Status of a Dedicated HSM instance:
    • Installing
      After you pay the initial installation fee, the purchased instance will be installed. The status of the Dedicated HSM instance will be Installing.
    • To be activated
      The status of an instance that has been installed but not activated is To be activated.
    • Creating
      After you have activated an instance, the system will allocate the instance to you according to your configuration. The instance is in the status of Creating during this process.
    • Creation failed
      Due to insufficient resources or network faults, an instance may fail to be created. In this case, the instance will be in the status of Creation failed.
    • Running
      After an instance is configured and allocated, it will be in the status of Running.
    • Frozen
      If an instance is not renewed upon its expiration, its status changes to Frozen.
    Service Edition
    Platinum edition: You can exclusively use the HSM subrack, power supply, the network bandwidth, and API resources of the HSM.
    AZ
    AZ of a device
    IP Address
    Floating IP address of the Dedicated HSM instance
    Expiration Time
    Expiration time of the purchased HSM instance.
  5. Locate a Dedicated HSM instance and click to view its details.
    For more information, see Table 2.
    Table 2 Parameter description
    Name
    Name of a Dedicated HSM instance
    ID
    ID of an instance
    Status
    • Installing
    • To be activated
    • Creating
    • Creation failed
    • Running
    • Frozen
    Service Edition
    HSM Type
    HSM types of an instance, including Finance, Server, and Signature verification server.
    VPC
    VPC to which the instance belongs
    For more information about VPC, see Virtual Private Cloud User Guide.
    Subnet
    Subnet where the instance is located.
    For more information about subnets, see Virtual Private Cloud User Guide.
    IP Address
    Security Group (SG)
    Security group to which the instance belongs
    For more information about security groups, see Virtual Private Cloud User Guide.
    Creation Time
    Time when the instance is purchased
    Expiration Time
    Time when the instance expires
    Order
    Order ID of the instance. You can click the order number to query the order details.
    Billing Mode
    Yearly/Monthly prepaid package
