- Billing
- Getting Started
User Guide
- Preparations
- CodeArts Req
- CodeArts Repo
- CodeArts Pipeline
- CodeArts Check
- CodeArts Build
- CodeArts Artifact
- CodeArts Deploy
- CodeArts TestPlan
- CodeArts PerfTest
Best Practices
- Best Practices Summary
Using CodeArts to Manage an e-Mall Development Project
- Overview
- Resource Planning
- Process
Implementation Procedure
- Preparation
- Step 1: Managing Project Plans
- Step 2: Managing Project Configurations
- Step 3: Writing Code
- Step 4: Checking Code
- Step 5: Building an Application
- Step 6: Deploying an Application (CCE)
- Step 6: Deploying an Application (ECS)
- Step 7: Managing Project Tests
- Step 8: Configuring a Pipeline for Continuous Delivery
- Releasing Resources
General
- How Do I Collect or Archive Project Information Locally After a CodeArts Project Is Complete?
- Why Can't an IAM User View Any CodeArts Projects After Login?
- How Do I View All CodeArts Projects and Members Under My Account as Administrator?
- Will the Tasks Created by a Project Member Be Deleted After the Member Leaves the Project?
- Will a New User with the Same Name as a Deleted User Inherit Their Permissions and Tasks?
- CodeArts Req
- CodeArts Repo
- CodeArts Pipeline
- CodeArts Check
- CodeArts Build
- CodeArts Artifact
- CodeArts Deploy
- CodeArts TestPlan
- CodeArts PerfTest
General
- Videos
Managing Project Permissions
CodeArts provides role-based access control (RBAC). New users do not have any permissions assigned by default. You need to first add them to one or more projects and then assign roles to these users. The users can perform specified operations on cloud services based on the permissions they have been assigned.
CodeArts has multiple built-in system roles. You can also create custom roles with desired permissions for CodeArts Req, CodeArts Repo, CodeArts Check, CodeArts Build, CodeArts Artifact, CodeArts Deploy, CodeArts TestPlan, and CodeArts Pipeline.
Modifying Permissions of a System Role
Ensure that you have permission to assign permissions in the project.
- The permissions of the project administrator role cannot be edited.
- The general permissions of the project manager role cannot be edited.
- Go to the CodeArts homepage.
- Log in to the CodeArts console, click
, and select a region.
- Click Access Service.
- Click the target project name to access the project.
- In the navigation pane, choose Settings > Permissions.
- In the role list, click the name of a desired role.
- Click a service name. The role's permissions for the service are displayed.
- Click Edit, modify the permissions, and click Save.
- Check the updated permissions.
Creating a Role
- Click the project name of interest.
- Click Create Role.
- In the displayed dialog box, configure the following information and click OK.
Table 1 Creating a role Parameter
Mandatory
Role Name
Yes
- Do not use the name of a system role.
- Enter a maximum of 30 characters, including letters, digits, spaces, and the following special characters: () [] - _ ~. & <> {}
Copy Role
No
Copy an existing role from a project of the same type.
- Check the new role under Custom Roles.
You can perform the following operations on the new role.
Table 2 Managing a custom role Operation
Editing the role's permissions
Modifying the role name
- Click
next to the role name and choose Modify Role Name.
- Enter a new name and click OK.
The updated role name is displayed.
Deleting the role
- Click
next to the role name and choose Delete Role.
- Enter YES and click OK.
The role is no longer displayed on the page.
- Click
Managing Permission Templates
When multiple projects require the same permission settings, you can configure permissions for one of the projects, and save the settings as a permission template to reuse in other projects.
Permission templates can be reused only between projects of the same type.
Each tenant can create up to 20 permission templates.
- Creating a Permission Template
- Click Save as Template.
Table 3 Saving permission settings as a template Parameter
Mandatory
Name
Yes
Enter a maximum of 64 characters, including letters and digits.
No
Enter a maximum of 256 characters, including letters, digits, spaces, and these special characters: , . () []
- Save the settings. Click the username
on the navigation bar and choose All Account Settings.
- Choose General > Permission Template. The saved permission template is displayed.
Users with the Tenant Administrator role can edit and delete permission templates.
- Using Permission Templates in a Project
- On the Permissions tab, click the Select Template drop-down list and select a template.
- Click OK.
- Check the updated role permissions.
