Importing Users from Another Project
If your account has multiple projects, you can import members of one project to another.
This section uses projects X and Y as an example. You can add the members of project X to project Y.
- Go to the CodeArts homepage.
- Log in to the CodeArts console, click
, and select a region where you have enabled CodeArts. - Click Go to Workspace.
If your account uses the old billing mode (see Old Billing Modes), click Access Service.
- Click the target project name to go to the project.
- In the navigation pane, choose Settings > Members.
- Click the Member View tab, click Add Members, and select From Another Project.
- In the displayed dialog box, select a project from the Project drop-down list. Members of the selected project are displayed.
- Select users, select a role from the Role drop-down list for each user, and click Save.
Figure 1 Importing users from another project
The new members are displayed in the list.
Helpful Links
- For details about the system roles in CodeArts projects, see built-in project roles in CodeArts.
- For details about how to edit and delete members, see Step 3: Manage Project Members.
- For details about how to configure permissions for each role in CodeArts, see Modifying Project Role Permissions.
