Managing Watermark Settings
CodeArts provides the watermark settings. You can set a watermark for CodeArts Req, CodeArts TestPlan, and other services to protect your sensitive information.
This function is not available in the following regions:
- AP-Singapore
- LA-Sao Paulo1
- LA-Mexico City2
Enabling/Disabling Watermarks
- Go to the CodeArts homepage.
- Log in to the CodeArts console, click
, and select a region where you have enabled CodeArts. - Click Go to Workspace.
If your account uses the old billing mode (see Old Billing Modes), click Access Service.
- Click the username
on the top navigation bar and choose All Account Settings. - Go to the General > Global Settings page, and enable or disable watermarking as needed.
Go to the relevant service, and check whether the watermark settings take effect.
