Managing Tenant Permissions
Tenant permissions apply to operations beyond CodeArts projects.
| Category | Description |
| General |
| CodeArts Artifact |
CodeArts provides tenant roles. You can also create custom ones as required.
| Role Name | Description |
| Owner | The creator of an account by default. This role has CodeArts' all tenant permissions, and its permissions cannot be edited. |
| Admin | Has CodeArts' all tenant permissions. Owner and Admin can edit this role's permissions. |
| Member | Has part of CodeArts' tenant permissions. Owner and Admin can edit this role's permissions. |
| Unauthorized user | Does not have any of CodeArts' tenant permissions. This role is not displayed in the role list. New IAM users created in your account are granted this role by default if no tenant-level role is configured. |
Managing System Role Permissions
- Go to the CodeArts homepage.
- Log in to the CodeArts console, click
, and select a region where you have enabled CodeArts. - Click Go to Workspace.
If your account uses the old billing mode (see Old Billing Modes), click Access Service.
- Click the username
on the top navigation bar and choose All Account Settings. - Choose General > Tenant Permissions from the navigation pane. The tenant permissions management page is displayed.
- In the role list, click the target role name, click Edit, select the required permissions, and click Save.
When a success message shows up, the role permission configuration is complete.
Creating a Role
on the top navigation bar and choose All Account Settings. - Choose General > Tenant Permissions.
- Click Create Role. In the displayed dialog box, configure the role information and click OK.
Table 3 Creating a role Parameter
Role Name
The name of the custom role. Do not use a system role name.
Enter a maximum of 30 characters. Letters, digits, spaces, and the following special characters are supported: () [] - _ ~. & <> {}
Copy Role
Copy permissions from an existing role in a project of the same type.
This parameter is optional. Enable it as needed. Once enabled, select a role type (system or custom) and a role name.
