Expanding a DESS Device
If the capacity of your DESS device is insufficient, you can expand it.
Context
For details about the capacity expansion of DESS device, see the following table.
Type |
Description |
Common I/O, common I/O (low latency) |
High I/O, high I/O (low latency) |
Ultra-high I/O, ultra-high I/O (low latency) |
- Log in to the management console. For details, see Logging In to the Management Console.
- Click
and select the wanted region. - Click
and choose Dedicated Cloud > Dedicated Enterprise Storage to go to the DeC management console.
- On the navigation pane on the left, choose Dedicated Enterprise Storage > DESS Devices to go to the DESS device list page.
- Click Expand in the row of the wanted DESS device. The Expand dialog box is displayed.
- Select the capacity to be added.
The total capacity must be 100 TB or less after expansion.
- Click Apply Now.
- Confirm the order information and click Submit.
Follow-Up Procedure
After submitting an order, in the upper right corner on the DESS home page, choose Fees > My Orders and click Details to view the order details.
For details about the DESS device capacity expansion order status, see Table 2.
Status |
Description |
Pending Approval |
Your order is in the Pending Approval state as soon as you submit the order. |
Pending |
The system administrator approves the order within three days. After the approval, the order status changes to Pending. |
Processing |
You can click Pay to pay for the order. After the payment, the order status changes to Processing. |
Completed |
The O&M personnel, after being notified, expands the capacity of the DESS device. When the order status changes to Completed, the capacity is successfully expanded. |
