Dedicated Enterprise Storage Service
User Guide
- Introduction
- Registration and Login
- Quick Start
- DESS Device Management
- DESS Management
- Cloud DR Replication
- What Is DESS?
- How Can I Select the Region?
- Is DESS Exclusively Used?
- Performing Post-Expansion Operations for a Windows Disk
- Performing Post-Expansion Operations for a Linux Disk (fdisk)
- Performing Post-Expansion Operations for a Linux Disk (Using Parted)
- Performing Post-Expansion Operations for a SLES Disk (fdisk)
- Change History
- Purchase Guide
- What Is DESS?
On this page
Show all
Help Center/
Dedicated Enterprise Storage Service/
User Guide/
Registration and Login/
Logging In to the Management Console
This section describes how to log in to the management console, on which you can access and use cloud services.
DeC has been provisioned. For details, see the Dedicated Computing Cluster User Guide.
- Log in to the HUAWEI CLOUD website at https://www.huaweicloud.com/intl/en-us/.
- Click Console in the upper left corner of the displayed page.
- Log in using your account.
If you do not have a cloud account, click Register and register one as prompted.
Parent topic: Registration and Login
