Deleting a HyperMetro Consistency Group
If a HyperMetro consistency group is no longer needed, you can delete it.
- A HyperMetro consistency group has been created and is in the Available state.
- You have confirmed that the HyperMetro consistency group to be deleted is no longer used.
Precautions
After a consistency group is deleted, the system cannot use the protection function of the HyperMetro consistency group. Before you perform this operation, ensure that the selected HyperMetro consistency group is no longer needed.
- Log in to the management console. For details, see Logging In to the Management Console.
- Click
and select the wanted region. - Click
and choose Storage > Dedicated Enterprise Storage Service to go to DESS Console.
- On the navigation pane on the left, choose HyperMetro Consistency Groups.
- (Optional) Set the search criteria to look for the desired consistency group.
- In the row of the consistency group, click Delete.
The Delete HyperMetro Consistency Group dialog box is displayed.
- If all disks are removed from the consistency group, you can directly delete them.
- If there are unmoved disks in the row, select
. If this option is selected, all disks will be removed.
- Understand the potential risk of this operation and click OK.
A message is displayed indicating a successful deletion.
