Downloading and Importing the Signature File
Before sending a disk to a Huawei DC, you need to save the signature file to the disk.
- You have created a DES order.
- You have copied the data.
- Log in to DES Console.
- Click Download signature file in the Operation column to download the signature file to the local host.
- Import the signature file to the root directory of the disk.
A signature file is the unique identifier for matching a DES order with disks in an order. One signature file is generated for one service order. After receiving the disk, the administrator mounts the disk to a server. The system automatically matches the disk with the service order to prevent misoperations caused by manual intervention. Table 1 shows the signature file information.
Table 1 Signature file Parameter
version
Specifies the service version ID.
OrderURN
Includes the service name, service region, identification code, and service order number.
- Copy the downloaded signature file to the root directory of the disk.
- When a service order has multiple disks, you need to copy the signature file to each disk.
