- What's New
- Getting Started
User Guide
Detailed Instructions on Using Teleport
- Process
- Logging In to DES Console
- Creating a Bucket
- Creating a Teleport-based DES Order
- Receiving Teleport and Connecting Cables
- Copying Data
- Downloading and Importing the Signature File
- Powering Off and Packing Teleport
- Sending Back the Teleport
- Starting Data Transmission
- Viewing Data Transmission Results
- Detailed Instructions on Using Disks
- Managing DES Orders
About the Service
- What Is DES?
- What Are the Advantages of DES Over the Internet in Data Transmission?
- What Are the Scenarios to Which DES Is Applicable?
- In What Conditions Is DES Recommended?
- Is the Data Volume Limited for DES?
- Where Is Data Uploaded by DES Stored?
- What Information Is Contained in the DES Transmission Report?
- What Are the Requirements for Disks by Disk-based DES?
- What Is Teleport?
- In What Conditions Is Teleport Recommended?
- What Are the Advantages of Teleport-based Transmission?
- What Is the Storage Capacity of a Teleport?
- What Is the Difference Between the Source Data Parameter and teleportshare?
- Can DES Provide Data Export Service?
- How Long Does It Take to Ship a Teleport?
- How Long Does It Take for My Data to Migrate to Huawei Cloud After I Have Created a DES Order?
Operations
- How Do I Subscribe to DES?
- Why Do I Need to Create OBS Destination Buckets When Using DES?
- Can I Post Several Disks with One Service Order?
- Can I Cancel a Submitted DES Order?
- How Do I Use a Teleport?
- In What Conditions Will I Be Notified by SMS Text Messages?
- How Can I Start Uploading Data After My Disk or Teleport Has Been Mounted?
- Does the Data Directory Structure Change After Data Is Uploaded to OBS Using DES?
- What Can I Do if the Device Is Damaged During DES Delivery?
- For Disk-based DES, How Do I Send a Disk?
- In Which Statuses Can a Service Order Be Modified?
Service Order Status
- How Can I Obtain the Status of a DES Service Order?
- What Are the Possible Statuses of a Disk-based Service Order?
- What Are the Possible Statuses of a Teleport-based Service Order?
- What Does Disk to be sent Mean?
- What Does Expired Mean?
- What Does Service order canceled Mean?
- What Does Access key (AK/SK) to be entered Mean?
- What Does Data transmitting Mean?
- What Does Disk to be sent back Mean?
- What Does Transmission failed Mean?
- What Does Order under review Mean?
- What Does Preparing device Mean?
- What Does Sending to user Mean?
- What Does Sending to Huawei Mean?
- What Does Staff signed Mean?
Security
- How Does DES Prevent Data from Being Stolen?
- How Does DES Ensure Data Security?
- What Is the Anti-Misoperation Mechanism of DES?
- What Is the Function of a Signature File?
- How Can I Obtain a Signature File?
- What Is the Content of a Signature File?
- Do I Need to Post the Signature File Along with the Disk or Teleport?
- Can Background Management Personnel Obtain My Data?
- How Does Teleport Ensure Data Security?
- How Does HUAWEI CLOUD Handle the Storage Media Used for Migration After Data Is Uploaded to HUAWEI CLOUD?
- Service Tariff
About the Service
- Glossary
Copying Data
Before the Teleport is mailed to you, a CIFS or NFS shared file system has been created as required by the administrator.
A CIFS shared file system is mounted to a Windows client. An NFS shared file system is mounted to a Linux or Unix client. Copying data to the mounted shared path is to copy it to the Teleport.
Copying Data Using a CIFS Shared File System
This section describes how to copy data using a CIFS shared file system.
- Your data to be uploaded is ready.
- The Teleport has been connected and configured.
- Log in to the Windows client.
- Right-click Computer and choose Map network drive.... The Map Network Drive dialog box is displayed.
- Mount the CIFS shared path.
Enter \\192.168.100.10\teleportshare in the Folder text box and click Finish.
192.168.100.10 is the logical port IP address modified by you, and teleportshare is the name of the shared file system. The name is created by the vendor of Teleport, and you do not need to create it.
- Copy local data to the teleportshare directory.
Copying Data Using an NFS Shared File System
This section describes how to copy data using an NFS shared file system.
- Log in to the Linux or Unix client.
- Mount the NFS shared file system.
Create a mount point, for example, mkdir -p /mnt/folder, in the local Linux/Unix system, and then run the mount -t nfs 192.168.100.10:/teleportshare /mnt/folder command.
- Copy the local data to the /mnt/folder directory.
