Process
Figure 1 and Table 1 describe how to use Teleport-based DES.
| Procedure | Description |
| Logging in to DES Console | Sign up for a HUAWEI ID and log in to DES Console. |
| Creating a bucket | Data is stored in OBS buckets. You must create a bucket on OBS before using DES. |
| Creating a DES order | You are advised to select a Huawei DC nearby and create a Teleport-based order. |
| Receiving the Teleport and connecting cables | Unpack and configure the device after receiving the Teleport from a Huawei DC. |
| Copying data | Copy local data to the Teleport storage system. |
| Downloading and importing the signature file | A signature file is the unique identifier of the Teleport in a service order. Before returning the Teleport, you must store the signature file in the teleportshare root directory. |
| Powering off and packing the Teleport | After all local data has been transmitted to the Teleport, power it off and pack it. |
| Sending back the Teleport | Send the Teleport back to the Huawei DC. The Teleport storage system that is sent back must contain the signature file. |
| Starting data transmission | Data upload starts after the administrator mounts the Teleport to a server and you enter the AK/SK. |
| Viewing the data transmission result | After data transmission is complete, you can download the generated data transmission report to check whether all data is successfully uploaded. |
