Creating and Deploying an Application Using the Docker Deployment Template (Linux)
You can install Docker on the host, log in to the remote repository, and perform operations such as build, push, and run.
- In the template selection step, select this system template by referring to Creating an Application Using a System Template.
The related deployment actions are shown in the following figure. Check whether you have installed Docker on the target host. If yes, remove the Install Docker action from the template.
- On the Deployment Actions page, configure the following actions. For details about the parameters, see below.
