Updated on 2026-01-21 GMT+08:00
Decompressing a File
This action aims to decompress a file from one path on a host to another path on the host.
Configuring Deployment Actions
  1. Create an application by referring to Creating an Application.
  2. On the Deployment Actions page, add this deployment action based on the service scenario.
  3. Configure the action using the parameters described in the table below.
    Table 1 Parameters
    Action Name
    Custom action name. Enter 1 to 128 characters. Do not start or end with a space. Use letters, digits, spaces, and these special characters: -_,;:./()
    Environment
    Deployment object. Select an environment whose resource type is host cluster.
    Decompress File
    Path of the file to be decompressed or stored.
    Action Control
    Whether to enable the settings.
    • Keep running on failure: Continue the task even if this action fails.
    • Execute this action with the sudo permission: Use the sudo permission to deploy this action.
Helpful Links
If you encounter any problems during deployment, see Decompressing a File.
