Updated on 2026-09-11 GMT+08:00
Installing Tomcat
Add this action to install Tomcat on a host.
Configuring Deployment Actions
  1. Create an application by referring to Creating an Application.
  2. On the Deployment Actions page, add this deployment action based on the service scenario.
  3. Configure the action using the parameters described in the table below.
    Table 1 Parameters for installing Tomcat
    Action Name
    Custom action name.
    Enter 1 to 128 characters. Do not start or end with a space. Use letters, digits, spaces, and these special characters: -_,;:./()
    Environment
    Deployment object. Select an environment whose resource type is host cluster.
    Tomcat Version
    Version of Tomcat to be installed.
    Installation Path
    Installation path of Tomcat.
    HTTP Port
    Default port: 8080
    AJP Port
    Default port: 8009
    Service Shutdown Port
    Default port: 8005
    Action Control
    Whether to enable the settings.
    • Keep running on failure: Continue the task even if this action fails.
    • Execute this action with the sudo permission: Use the sudo permission to deploy this action.
Helpful Links
If you encounter any problem during deployment, see Installing Tomcat.
