Updated on 2026-01-21 GMT+08:00
Starting or Stopping Node.js
This action aims to start or stop Node.js in a specified path on a host.
Configuring Deployment Actions
  1. Create an application by referring to Creating an Application.
  2. On the Deployment Actions page, add this deployment action based on the service scenario.
  3. Configure the action using the parameters described in the table below.
    Table 1 Parameters
    Action Name
    Custom action name. Enter 1 to 128 characters. Do not start or end with a space. Use letters, digits, spaces, and these special characters: -_,;:./()
    Environment
    Deployment object. Select an environment whose resource type is host cluster.
    Operation
    Start and Stop are available.
    Absolute Path
    Path of the Node.js service.
    Command Parameters
    Optional.
    • The Node.js running parameters refer to the parameters of application.
    • If you choose Start for Operation, you can configure parameters, such as the listening port of Node.js to start Node.js.
    Action Control
    Whether to enable the settings.
    • Keep running on failure: Continue the task even if this action fails.
    • Execute this action with the sudo permission: Use the sudo permission to deploy this action.
Helpful Links
If you encounter any problem during deployment, see Starting or Stopping Node.js.
