Updated on 2026-01-21 GMT+08:00
Deploying an Application on CCE Clusters Using ServiceStage
You can deploy applications on Huawei Cloud CCE clusters using Huawei Cloud ServiceStage.
  1. In the template selection step, select this system template by referring to Creating an Application Using a System Template.
    The related deployment actions are as follows:
  2. On the Deployment Actions page, configure the action. For details about the parameters, see Deploying an Application on ServiceStage 2.0.
This template is available only at the LA-Mexico City2, LA-Santiago, and AF-Johannesburg regions.
