Creating a Common Application by Running the Shell Script
You can deploy a general application using Shell scripts.
- In the template selection step, select this system template by referring to Creating an Application Using a System Template.
The related deployment actions are as follows:
- On the Deployment Actions page, configure the following actions. For details about the parameters, see below.
- Table 1 describes the parameters to be set in the template.
Table 1 Template parameters Parameter
host_group
Target environment where the application is deployed.
package_url
Software package download link. To obtain it, go to the Artifact > Release Repos page.
app_name
Application name to obtain the process ID and stop the process.
service_port
Application port.
