Help Center/
CodeArts Deploy/
User Guide/
Creating and Deploying an Application Using a Preset Template/
Creating and Deploying an Application Using ServiceStage/
Deploying an Application on ECS in an AS Group Using ServiceStage
Updated on 2026-01-21 GMT+08:00
You can deploy applications on Huawei Cloud ECSs in AS groups using Huawei Cloud ServiceStage.
- In the template selection step, select this system template by referring to Creating an Application Using a System Template.
The related deployment actions are as follows:
- On the Deployment Actions page, configure the action. For details about the parameters, see Deploying an Application on ServiceStage 2.0.
This system template is available only at the LA-Santiago region.
