Help Center/ CodeArts Deploy/ User Guide/ Creating an Application/ Creating an Application Using a Preset Template/ Creating an Application Using the ServiceStage Template/ Deploying an Application on ECS Based on ServiceStage
Updated on 2026-09-11 GMT+08:00
You can deploy applications on Huawei Cloud ECSs using Huawei Cloud ServiceStage.
This system template is available only in the Santiago region.
- In the template selection step, select this system template by referring to Creating an Application Using a System Template.
The related deployment actions are as follows:
- On the Deployment Actions page, configure the action. For details about the parameters, see Deploying an Application on ServiceStage 2.0.
0
3
4
5
6
7
8
9
10
Very dissatisfiedVery satisfied
