Help Center/ CodeArts Deploy/ User Guide/ Configuring an Environment
Updated on 2026-11-25 GMT+08:00
During digital transformation, many applications need to be deployed quickly. In this case, an effective deployment method is required. The concept of environment arises accordingly. An environment is a set of one or more hosts running the same operating system. The environment is a deployment object in an application. It integrates multiple hosts to deploy applications in batches. This approach eliminates the need to deploy applications separately on each host. By running deployment commands once for the environment, applications can be efficiently and consistently deployed across multiple hosts. This method improves deployment efficiency and reduces the risk of human errors.
For host deployment scenarios, you can add, delete, and modify the environments of the application on the Environment Management tab page. You can also import, query, and delete hosts in the environment. The environments are important components of service deployment. This section describes how to configure an environment in an application.
  • For details about the maximum number of environments that can be created under an application, see Specifications and Constraints > Basic constraints > Environment management.
  • For details about the maximum number of hosts that can be imported to an environment, see Specifications and Constraints > Basic constraints > Application management.
  1. Click the target application in the application list, click , and click Edit. The Deployment Actions page is displayed.
  2. Click the Environment Management tab.
  3. Create an environment.
    1. Click Create Environment, set the following parameters, and click Save.
      Table 1 Parameters for creating an environment
      Environment
      Enter a custom environment name.
      Enter 3 to 128 characters. Use digits, letters, hyphens (-), underscores (_), and periods (.).
      Resource Type
      You can choose Host based on the environment requirements.
      OS
      Choose Linux or Windows as the operating system for the host.
      Enter a description of the environment.
      Max. 500 characters.
    2. Click Import Host. The system automatically filters all clusters that meet the requirements of the current environment. Select a target host cluster and import a host to the environment in either of the following ways:
      Import separately: Click in the Operation column of a host to import the host to the environment.
      Import in batches: Select multiple hosts and click Import.
      If you import a target host bound to an agent host, the agent host will be imported to the environment automatically.
    3. (Optional) After the host is imported, click on the page to verify the connectivity.
      For details about connectivity verification, see Host Management.
  4. Modify the environment.
    1. Edit the environment.
    2. Edit the host cluster.
      • Editing an environment: Click in the Operation column of an environment to modify the environment name and description.
      • Deleting an environment: Click in the Operation column of an environment, and click Yes.
      • Managing permissions: Click in the Operation column of an environment to configure operation permissions for each role. Enable or disable permissions as required.
        For details about the permissions of each role, see Configuring Environment Permissions.
    3. Edit a host in the environment.
      • Verify host connectivity in batches: Select multiple hosts and click .
      • Enable network connectivity verification: Click in the Operation column of a host.
      • Delete a host: Click in the Operation column of a host, click Delete, and click OK.
        An agent host cannot be deleted. An agent host is removed when the last target host is deleted from the environment.
  5. After modifying all information, click Save.
