CodeArts Deploy Overview
CodeArts Deploy is a visualized and automatic deployment service. It provides various deployment actions for you to customize deployment process, improving efficiency and reducing costs.
CodeArts Deploy has the following features:
- CodeArts Deploy supports deployment on hosts (Huawei Cloud ECSs, your own hosts, and third-party hosts) or containers (Huawei Cloud CCE clusters, on-premises clusters, and third-party clusters).
- Functions are encapsulated as plug-ins which are easy to use. Common applications can be deployed out of the box.
- CodeArts Deploy provides system templates such as Tomcat, Spring Boot, and Django for you to deploy tasks quickly.
- You can drag and drop atomic actions to orchestrate and assemble applications, customize application templates, and create applications within a few clicks.
You can use CodeArts Deploy to deploy a project. The following figure shows the workflow.
The operations involved are as follows:
- Create basic resources: Prepare for the deploy environment.
- Create an application: Quickly set up an application based on the service plan or using templates.
- Import basic resources: Import target host to be deployed.
- Edit an application: Configure deployment actions and parameters.
- Deploy an application: Start the application deployment.
