Creating and Deploying an Application Using the Go Application Deployment Template
Deploy a Go web service on the host and start the service.
You have installed Go on the target host. Remove the Install Go action from the template.
The related deployment actions are as follows.
The table below describes the parameters to be set in the template.
Parameter |
Description |
host_group |
Target environment where the application is deployed. |
package_url |
Software package download link. To obtain it, go to the Artifact > Release Repos page. |
app_name |
Application name to obtain the process ID and stop the process. |
service_port |
Application port. |
