Deploying an Application on ServiceStage 2.0
ServiceStage is an application and microservice management platform that facilitates application deployment, monitoring, O&M, and governance.
ServiceStage supports Container deployment, AS Group, and ECS. You can select a deployment system based on project requirements.
This action is not available in the ME-Riyadh, AF-Cairo, and AP-Singapore regions.
- You have created an application on ServiceStage.
- You have created and deployed a component on ServiceStage.
- You have created an environment on ServiceStage.
Parameter |
Description |
Action Name |
Custom action name. Enter 1 to 128 characters. Do not start or end with a space. Use letters, digits, spaces, and these special characters: -_,;:./() |
Tenant |
Mandatory. There are two options:
You are advised to configure the AK/SK of a user who has the CCE cluster operation permission and not advised to configure the AK/SK of a tenant account. |
Region |
Region where ServiceStage is deployed. |
Deployment System |
Supports Container deployment, AS Group, and ECS. |
Application |
Select the application created in ServiceStage. |
Stack |
Docker or other technology stacks. |
Component |
Select the component to be deployed. |
Component Version |
The component version number is used to roll back the component in ServiceStage. |
Environment |
Select the environment to be deployed. |
Cluster |
Select the CCE cluster to be deployed in the preceding environment. |
Namespace |
Namespace where the component is to be deployed in the CCE cluster. |
Instances |
Enter the number of pods of the component. |
Image |
Select the image to be deployed. (Push the required image to SWR). |
Image Tag |
Select an image tag. |
Container Specifications |
Select specs:
Action Control |
Continue the task even if this action fails. |
Parameter |
Description |
Action Name |
Region |
Deployment System |
Application |
Component |
Component Version |
Environment |
ECS |
Select the ECS to be deployed. |
Select Deployment Source |
Artifact: Select an existing software package from Artifact. OBS: Select the software package uploaded using OBS. |
Action Control |
Parameter |
Description |
Action Name |
Region |
Deployment System |
Supports Container deployment, ECS, and AS Group. |
Application |
Component |
Component Version |
Environment |
AS Group |
Select the AS group to be deployed. |
AS Instance |
Select the AS group instance to be deployed. |
Action Control |
