Help Center/ CodeArts Deploy/ User Guide/ Configuring CodeArts Deploy Application Notifications
Updated on 2026-09-11 GMT+08:00
On the Notifications tab page, you can set notification rules to send events to the application creator, executor, and follower. This section describes how to configure notifications.
  1. Click the target application in the application list, click , and click Edit. The Deployment Actions page is displayed.
  2. Click Notifications.
  3. To set event notifications, click (indicates that the notification is enabled) or (indicates that the notification is disabled) as required.
    • System message: Application updates will be pushed via messages.
    • Email: Application updates will be pushed to the application creator, executor, and members who have favorited the application via emails.
  4. (Optional) Click Use Project Notification Settings to sync settings for From CodeArts Deploy, Email, and System Messages.
    1. If Use Project Notification Settings is enabled for From CodeArts Deploy, the current notification settings will be overwritten. For details, click Tips in the upper right corner.
    2. If Use Project Notification Settings is disabled for From CodeArts Deploy, the current notification settings will restore to the parameters configured before.
  5. After modifying all information, click Save.
