Editing the Deployment Actions of the CodeArts Deploy Application
On the Deployment Actions tab page, you can delete, edit, add, and drag deployment actions. This section describes how to configure deployment actions.
- Select the target application, click
, and click Edit. The Deployment Actions page is displayed.
- Add an action.
Click
above or below an added action. All actions that can be added are displayed in the right pane. You can add an action before or after the current action. - Modify the action details.
Click the target action and modify the action details in the right pane.
- Copy, delete, or disable an action.
Click
and click Clone to clone the action to the current application.Click
and click Delete to delete the action from the current application.Click
and click Disable to disable the action in the current application. - Adjust the execution sequence of actions.
- Add an action.
- Click Save.
