Installing JDK
This action aims to install JDK on a host. The following table describes the configuration parameters.
Parameter |
Mandatory |
Description |
Action Name |
Yes |
Custom action name. Enter 1 to 128 characters. Do not start or end with a space. Use letters, digits, spaces, and these special characters: -_,;:./() |
Environment |
Yes |
Deployment object. Select an environment whose resource type is host cluster. |
JDK Version |
Yes |
JDK version. |
Installation Path |
Yes |
Installation path of JDK. |
Action Control |
No |
You can configure whether to enable the settings.
When purchasing a Huawei Cloud ECS, you are advised to select Arm-based CentOS, Ubuntu, or Huawei Cloud EulerOS. Arm-based EulerOS does not have the yum source of openjdk-11.
If you encounter any problems during deployment, see Installing JDK.
