Help Center/ Dedicated Host/ User Guide/ Using IAM to Grant Access to DeH/ Using IAM Roles or Policies to Grant Access to DeH
Updated on 2026-10-22 GMT+08:00
System-defined permissions in Role/Policy-based Authorization provided by Identity and Access Management (IAM) let you control access to DeH. With IAM, you can:
  • Create IAM users in your account for personnel based on your enterprise's organizational structure. Each IAM user has their own security credentials for accessing DeH resources.
  • Grant users only the permissions required to perform a given task based on their job responsibilities.
  • Entrust an account or a cloud service to perform efficient O&M on your DeH resources.
If your account does not require individual IAM users, you can skip this section.
Figure 1 shows the process flow of role/policy-based authorization.
Before granting permissions to user groups, learn about system-defined permissions in Role/Policy-based Permissions Management for DeH. To grant permissions for other services, learn about all system-defined permissions supported by IAM.
Process Flow
Figure 1 Process of granting DeH permissions using role/policy-based authorization
  1. On the IAM console, create a user group and grant it permissions (DeH ReadOnlyAccess as an example).
    Create a user group on the IAM console and assign the DeH ReadOnlyAccess permissions to the group.
  2. Create an IAM user and add it to the created user group.
    On the IAM console, create a user and add it to the user group created in 1.
  3. Log in as the IAM user and verify permissions.
    In the authorized region, perform the following operations:
    • Choose Service List > Dedicated Host. Then click Buy DeH on the DeH console. If a message appears indicating that you have insufficient permissions to perform the operation, the DeH ReadOnlyAccess policy is in effect.
    • Choose another service from Service List. If a message appears indicating that you have insufficient permissions to access the service, the DeH ReadOnlyAccess policy is in effect.
Example Custom Policies
You can create custom policies to supplement the system-defined policies of DeH. For details about actions supported in custom policies, see Actions Supported by Policy-based Authorization.
To create a custom policy, choose either visual editor or JSON.
  • Visual editor: Select cloud services, actions, resources, and request conditions. This does not require knowledge of policy grammar.
  • JSON: Create a JSON policy or edit an existing one.
For details, see Creating a Custom Policy. The following lists examples of common DeH custom policies.
Example 1: Grant permission to buy a DeH.
    "Version": "1.1",
    "Statement": [
            "Effect": "Allow",
            "Action": [
                "deh:dedicatedHosts:create"
