- What's New
- Product Bulletin
- Billing
- Getting Started
User Guide
- Function Overview
- Kernel Version Notes
- Permissions Management
Instance Management
- Instance Statuses
- Buying a DDM instance
- Splitting Read-only and Read-Write Services
- Changing Node Class
- Scaling Out a DDM Instance
- Scaling In a DDM Instance
- Restarting a DDM Instance or an Instance Node
- Deleting Pay-per-Use Instances
- Reloading Table Data
- Changing a Parameter Template
- Modifying Parameters of a DDM Instance
- Rolling Back the Version of a DDM Instance
- Upgrading the Version of a DDM Instance
- Upgrading the DDM Engine and OS
- Connection Management
- Schema Management
- Shard Configuration
- Data Nodes
Parameter Template Management
- Instance Parameters
- Creating a Parameter Template
- Modifying a Custom Parameter Template
- Comparing Two Parameter Templates
- Viewing Parameter Change History
- Replicating a Parameter Template
- Applying a Parameter Template
- Viewing Application Records of a Parameter Template
- Modifying the Description of a Parameter Template
- Deleting a Parameter Template
- Account Management
- Backups and Restorations
Data Migration
- Overview
- Migration Evaluation
- Scenario 1: Migrating Data from an On-Premises MySQL Instance to DDM
- Scenario 2: Migrating Data from a Third-Party Cloud MySQL Instance to DDM
- Scenario 3: Migrating Data from an ECS-hosted MySQL Instance on Huawei Cloud to DDM
- Scenario 4: Exporting Data from a DDM Instance
- Scenario 5: Migrating Data from Heterogeneous Databases to DDM
- Scenario 6: Migrating Data from Huawei Cloud RDS for MySQL to DDM
- Session Management
- Slow Queries
- Monitoring and Alarm Reporting
- Task Center
- Tags
- Auditing
SQL Syntax
- Introduction
- DDL
- DML
- Online DDL
- Functions
- Unsupported Objects and Use Constraints
- Supported SQL Statements
- Global Sequence
- Database Management Syntax
- Advanced SQL Functions
- Quotas
API Reference
- Before You Start
- API Overview
- Calling APIs
APIs (Recommended)
DDM Instances
- Querying DDM Instances
- Querying Details of a DDM Instance
- Modifying the Name of a DDM Instance
- Changing the Security Group of a DDM Instance
- Deleting a DDM Instance
- Scaling in a DDM instance
- Modifying the Read Policy of the Associated DB Instance
- Synchronizing Data Node Information
- Querying Nodes of a DDM Instance
- Querying Details of a DDM Instance Node
- Querying Parameters of a Specified DDM Instance
- Querying DDM Engine Information
- Querying DDM Node Classes Available in an AZ
- Changing the Node Class of a DDM Instance
- Obtaining the Instance Group Information
- Creating an Instance Group
- Schemas
- Accounts
- Monitoring
- Application Examples
DDM Instances
- Appendix
- SDK Reference
Best Practices
- Overview
- Formulating Sharding Rules
- Determining the Number of Shards in a Schema
- Using Broadcast and Unsharded Tables
- Transaction Models
- SQL Standards
- Migrating an Entire RDS Database to DDM
- Migrating an Entire MyCat Database to DDM
- Accessing DDM Using a JDBC Connection Pool
- Logging In to a DDM Instance Using Navicat
- Migrating Data from RDS for MySQL to DDM Using DRS
- Sharding Database and Table Data of an RDS for MySQL Instance
- Performance White Paper
- General Questions
DDM Usage
- How Does DDM Perform Sharding?
- What Do I Do If I Fail to Connect to a DDM Instance Using the JDBC Driver?
- Why It Takes So Long Time to Export Data from MySQL Using mysqldump?
- What Do I Do If a Duplicate Primary Key Error Occurs When Data Is Imported into DDM?
- What Should I Do If an Error Message Is Returned When I Specify an Auto-Increment Primary Key During Migration?
- What Do I Do If an Error Is Reported When Parameter Configuration Does Not Time Out?
- Which Should I Delete First, a Schema or its Associated RDS Instances?
- Can I Manually Delete Databases and Accounts Remained in Data Nodes After a Schema Is Deleted?
- SQL Syntax
RDS-related Questions
- Is the Name of a Database Table Case-Sensitive?
- What Risky Operations on RDS for MySQL Will Affect DDM?
- How Do I Handle Data with Duplicate Primary Keys in a Table?
- How Can I Query RDS for MySQL Information by Running Command show full innodb status?
- What Should I Pay Attention to When Selecting RDS for MySQL Instance Specifications?
- Resource Freezing, Release, Deletion, and Unsubscription
- Videos
More Documents
- Getting Started
- Function Overview
- Instance Management
- Editing a Parameter Template
- Task Center
- Schema Management
- Backup Management
- Monitoring Management
- Auditing
SQL Syntax
- Introduction
- DDL
- DML
- Functions
- Unsupported Items
- Global Sequence
- General Questions
DDM Usage
- How Can I Rectify a Fault in Accessing DDM by Using the JDBC Driver?
- What Version and Parameters Should I Select?
- How Should I Handle the Duplicate Primary Key Error Occurring After Data Is Imported into DDM?
- What Should I Do If an Error Message Is Returned After I Specify an Auto-Increment Primary Key?
- How Do I Handle the Error Reported When Parameter Configuration Does Not Time Out?
- Which Should I Delete First, Schema or Associated RDS DB Instances?
- Should I Manually Delete Databases and Accounts Remained in the Associated RDS DB Instances After a Schema Is Deleted?
- SQL Syntax
- RDS-related Questions
- Getting Started
- Function Overview
- Task Center
- Schema Management
- Backup Management
- Auditing
SQL Syntax
- Introduction
- DDL
- DML
- Functions
- Unsupported Items
- Global Sequence
- General Questions
DDM Usage
- SQL Syntax
- Before You Start
- API Overview
- Calling APIs
DDM Instance Management
- Querying the Quota of Classes Available in Each AZ
- Creating a DDM Instance
- Viewing Details of a DDM Instance
- Modifying the Security Group of a DDM Instance
- Scaling Out a DDM instance
- Scaling In a DDM instance
- Synchronizing DB Instance Data
- Schema Management
- Appendix
- Change History
Enabling Read/Write Splitting
DDM optimizes its read/write splitting function. In earlier versions, read/write splitting is automatically enabled after read replicas are added. From this version on, read/write splitting needs to be manually enabled after read replicas are added, and you can set read weights for your primary instance and read replicas.
You can enable or disable read/write splitting based as needed.
Precautions
The DDM kernel version must be 3.1.0 or later.
- Log in to the DDM console.
- On the Instances page, locate the DDM instance that you want to enable read/write splitting for.
- Click the instance name and go to the Basic Information page.
- Choose Data Nodes in the left navigation pane and click Enable Read/Write Splitting.
- For an RDS for MySQL instance, enabling read/write splitting will set the read weight of the primary instance to 100. You can adjust read weights of the primary instance and its read replicas based on your service requirements.
- There may be a noticeable latency in the data because read replica data is asynchronously replicated from the primary instance.
- After read/write splitting is enabled, read queries will be distributed to the primary or a read replica based on the configured read weight. There may be a replication delay for queries distributed to the read replica. For query statements that are not in the same transaction but logically depend on the data written in the previous transaction, you can add /*+ db_type=master*/ to the query statement. This hint forcibly enables the the primary node to process the query, ensuring that the latest data written by the previous transaction can be queried.
Disabling Read/Write Splitting
- On the Instances page, locate the DDM instance that you want to disable read/write splitting for.
- In the navigation pane on the left, choose Data Nodes.
- Click Disable Read/Write Splitting.
After read/write splitting is disabled, the preset weights will not work any more. Read/Write requests are processed only on the primary instance, so workloads using the primary instance may be affected.
