RIGHT_SHIFT
Updated on 2023-10-09 GMT+08:00
Application Scenarios
This algorithm applies if a large difference appears in high-digit part but a small difference in low-digit part of sharding key values. Using this algorithm ensures uniform distribution of remainders calculated from sharding key values. Therefore, data is evenly routed to different shards.
Instructions
The sharding key value is an integer.
Data Routing
The data route depends on the remainder of the new sharding key value divided by the number of database or table shards. To change the sharding key value, you need to convert the value into a binary number and right shift its bits to gain a new binary number. The number of moved bits is specified in DDL statements. Then, convert the new binary number into a decimal number. This decimal number is the changed sharding key value.
Calculation Method
Table 1 Required calculation methods
Condition
Calculation Method
Example
Database sharding key ≠ Table sharding key
Database routing result = Database sharding key value % Database shards
Table routing result = Table sharding key value % Table shards
Database shard: (123456 >> 4) % 8 = 4
Table shard: (123456 >> 4) % 3 = 0
Database sharding key = Table sharding key
Database routing result = Sharding key value % Database shards
Table routing result = (Sharding key value % Database shards) x Table shards + (Sharding key value / Database shards) % Table shards
Table table: ((123456 >> 4) % 8) x 3 + ((123456 >> 4) / 8) % 3 = 13
Syntax for Creating Tables
create table RIGHT_SHIFT(
	id int,
	name varchar(30) DEFAULT NULL,
	create_time datetime DEFAULT NULL,
	primary key(id)
) ENGINE = InnoDB DEFAULT CHARSET = utf8
dbpartition by RIGHT_SHIFT(id, 4)
tbpartition by RIGHT_SHIFT(id, 4) tbpartitions 2;
Precautions
The number of shifts cannot exceed the number of bits occupied by the integer type.
