Help Center/
      Distributed Database Middleware/
        User Guide/
        Instance Management/
      Scaling In a DDM Instance
        Updated on 2024-07-30 GMT+08:00
This section describes how to scale in a DDM instance as service data volume decreases.
Precautions
- Scaling in a DDM instance will not interrupt services.
- Scale in your DDM instance during off-peak hours. For pay-per-use instances, nodes are removed after the scale-in request is submitted.
- Make sure that the associated data nodes are normal and not undergoing other operations.
- At least one node should be left for a DDM instance.
- After a read-only group is created, the entry for removing nodes will be moved to the operation column of the group.
- Log in to the DDM console.
- On the Instances page, locate the instance that you want to remove nodes from and click its name.
- Click Scale In. If a group is created, click More > Scale In in the Operation column in the Group Information area.
- On the displayed page, view the current instance configuration and specify the number of nodes to be removed.
    Figure 1 Specifying the number of nodes to be removed
- Click Next.
- On the displayed page, click Submit if all configurations are correct.
   Parent topic: Instance Management
