Help Center/ Distributed Database Middleware/ User Guide/ Parameter Template Management/ Deleting a Parameter Template
Updated on 2023-10-09 GMT+08:00
You can delete parameter templates that are no longer needed.
Precautions
- Deleted parameter templates cannot be recovered. Exercise caution when performing this operation.
- Default parameter templates cannot be deleted.
- Log in to the DDM console.
- Choose Parameter Templates, click the Custom Templates tab, locate the template that you want to delete, and click More > Delete in the Operation column.
- In the displayed dialog box, click Yes.
Parent topic: Parameter Template Management
